I was trying to set up a system that had a dedicated pump, tank, injector, and injector controller, (pulse width of map vs rpm, the whole thing would basically be identical to a fuel system) but eventually said f it because I was too lazy to figure out a way to make it 100% failsafe. It would need to have pressure switches and pulse width monitoring, with the ability to trigger a boost cut upon failure to qualify for my definition of failsafe. I would hate to blow my engine because of something like that..that would be almost as bad as going lean because your tank was low and your pickup tube got starved halfway down the track..
be sure to always run distilled water, obviously, and let us know how it goes.. I guess this is becoming more popular with evo guys these days, but even with knock sensing, I don't know if I'd try very many of these systems on the market these days.. except maybe that aquamist system, which is very similar to what I wanted to build, programmable and if I remember correctly, over $1k..
