Results 1 to 4 of 4
Thread: Lights dont work
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    Lights dont work
    Alright, last week on friday I cracked up my car. Busted up a headlight and side markers/signal light and stuff. No metal damage luckily. So I replaced all the broken crap with parts from my other car and everything is good to go (except for hood, which ill do later... irrelavant nonetheless) and I have no lights. Both headlights work and the rear signal lights work/reverse lights and front bumper signals. However, the side markers and the front running lights and rear running lights dont work. Same with interior cluster.
    I quickly looked over the fuses, but none of them were blown (from what I can tell) and I checked the fuses under the hood. I manged to fix my clock not workin though
    Anyone know which fuse it is? This similar problem happened to me before on my other car and I know it was a fuse under the panel, but the fuses look fine. Maybe its a light break and I couldnt actually see it. Thanks.
    SEi User
    Mar 2005
    Saskatoon
    Re: Lights dont work
    bit of an update, pulled each fuse out and tested continuity, turns out the 15 was bad for the tail lights fuse. Lights are good but the side turn signals dont work....
    LXi User TheWatcher's Avatar
    Feb 2005
    1989 Honda Accord LX
    Quote Originally Posted by FyreDaug
    Take fuse(s) of the correct rating that are KNOWN to work and use them to test the fuse(s) for the sidemarkers, etc. This is very basic troubleshooting.
    If the fuse(s) test okay, then you need to break out the multimeter and start checking for a short somewhere.
    BTW, make sure the bulbs you're using work.
    Peace.
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    theres also a grey box under the center console behind the radio/head unit that controls the door ding/side markers...
    might of came unplugged or something, check into it.
  1. Gauges dont work part2
    By ahmad89 in forum 3geez Accords
    Last Post: 05-14-2007, 06:51 PM
  2. Brakes Dont Work Help!!
    By ahmad89 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-15-2007, 09:46 AM
  3. Windows And Starter Dont Work?
    By accordmanracing in forum 3geez Accords
    Last Post: 03-06-2007, 12:16 PM
  4. Replies: 2
    Last Post: 08-15-2004, 01:19 PM
  5. a/c dont work nomore
    By 89BlackH-Back in forum 3geez Accords
    Last Post: 08-27-2002, 12:18 PM
