http://autos.msn.com/research/compar...=t1421&v=t1418
apparently those 2 accords have the same block, but the bore and the stroke are different. is this an error?
i have an 86 EXi and that auto page only goes back to 88. i gotta rebuild my engine soon enough, but would i have any problems if i happen to buy a carbed block and an EFI rebuild kit? im asking mainly cause that page lists the bore/stroke different on the same engine block.
i also see the compression ratio isa bit different. would i benefit a bit from using the carbed block with the lower compression ratio for turbocharging? i dont plan to run much boost, maybe 7-10PSI
