Results 1 to 10 of 10
Thread: Clutch Won't disengage
    DX User dillirk's Avatar
    Jan 2004
    89 Honda Accord SEi
    Salt Lake City, UT
    Everything feels normal when you step on the clutch except it doesn't disengage. I thought I had snapped the cable but it is fine. Is it possable that something broke off and is jammed in the clutch?
    Re: Clutch Won't disengage
    One of the fingers on the pressure plate could have broke,
    Has the car sat a long time? The clutch may be stuck on the splines from rust or just stuck to the pressure plate.
    Only thing is to try and drive it and hope it breaks apart or the transmission needs to come out.
    Jan 2004
    89 Honda Accord SEi
    Salt Lake City, UT
    Thats what I was afrade of. It hasnt sat at all, my wife was driving it home last night and when we got off our exit it wouldn't work. I don't have time for this. But thats what I get for going to autozone for a clutch.
    LX User white ricer's Avatar
    89 Accord Lx-i
    Albany, Oregon
    yeah is the clutch stiff/loose? does it return after you push it down? like blueaccord said the fingers on the pressre plate could be effed up, the throwout bearing/clutch fork.. probably the best thing wouldbe drop the tranny on a weekend and inspect the clutch. my .02
    ^the new ride^ Mazda rx-7.. gettin 'r done without pistons since 1978
    "Spoiler size is inversely proportional to wee-wee size"
    the ex - 3rd gen owner
    Jan 2004
    89 Honda Accord SEi
    Salt Lake City, UT
    Every thing works the way it should as far as stiffness and the fork arm on the outside it just doesnt disengage. I hadn't thought of the fingers falling off but thats how its acting.
    Double check the clutch cable as well. Maybe it slipped somehow down by the tranny.
    Mine got fubared and I just thought the clutch was bad and went with it. Finally the old lady couldnt drive it so I decided to look at it and the clutch cable was not in its holder right somehow it popped out.
    i had the same thing happen the spring on the throw out bearing has broken and when u pushed in only 1 side of spring is pulling back an binding on shaft hte spring is shaped in a u with fingers on top of u to go into throw out bearing reachin to where cable goes to shifting arm on moter and see if arm will move try to push down or pull up if it is stuck it will probely be pulled up and there will be slack in cable
    also as far as auto zone clutchand pressure plates theyyyyy really stink im on my 4th one with my 89lxi. pressure plate keeps sticking. since 10 of 05 up till now
    Jan 2004
    89 Honda Accord SEi
    Salt Lake City, UT
    Problem solved. New NAPA clutch (not rebuilt) installed sunday. One of the springs on the clutch hub had broken out and was jammed between the clutch and pressure plate.
    Down with Auto Zone.
    well kewl you got it fixed sucks that it was the clutch.
  1. 5 speed, clutch doesnt disengage
    By AccordEpicenter in forum 3geez Accords
    Last Post: 04-28-2010, 06:52 AM
  2. 89 prelude clutch pedal or cLuTcH problem!?!
    By myaccord7 in forum Classic Preludes
    Last Post: 10-14-2006, 10:45 AM
  3. clutch slip but no mormal clutch smell
    By ghettogeddy in forum 3geez Accords
    Last Post: 06-22-2006, 10:36 PM
  4. Replies: 5
    Last Post: 12-13-2005, 02:33 AM
  5. stage 1 clutch from Clutch Master or Nippon
    By MarioBurke in forum Performance
    Last Post: 07-11-2003, 11:25 PM
