Results 1 to 25 of 25
Thread: Crazy Idle
    DX User bucket_man's Avatar
    88 Honda Accord Si (LX-i)
    Newcastle, Australia
    Crazy Idle
    Hey guys,
    Ever since ive had the car its had this wierd idle problem.
    when i start it, it will rev up to about 2000rpm then sometimes if i take off before i let it warm up a bit (sometimes if i dont even take off) it will start revving up and down by itself, usually it will rev up to 2000 then down to 1500 then back up, like a sine curve.
    Just wondering wether i should be worried and fix it or just let it go.
    thanks
    Paul
    '88 Accord 2.0 Si (LX-i)
    LX User chainz's Avatar
    Jun 2005
    89 LXi Sedan (good); 88 LX Sedan (rusted beater); 88 LXi Coupe (will be 5spd tranny doner)
    Columbus, OH
    Re: Crazy Idle
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    Re: Crazy Idle
    Hehe... I remember when my car did that chainz... Easy fix... but quite annoying
    so answer his question already :P
    SEi User B16KILLA's Avatar
    SO,CAL
    Re: Crazy Idle
    Quote Originally Posted by chainz
    My car is starting to do that alot . What is it?
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    Quote Originally Posted by Deadhead
    I wish I knew - the video is from my car. Can you help me out Deadhead... or anybody?
    SO,CAL
    Re: Crazy Idle
    I went and got an idle air control valve , but I havent had a chance to put it on yet if it works i'll let you know
    Hondaisok
    Guest
    Re: Crazy Idle
    Chainz: Your link is trying to put adware on my pc. Anyone else have this problem?
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    Quote Originally Posted by Hondaisok
    Shouldn't be - its just a windows media file on my PutFile account.
    Did you accidentally click on any of PutFiles advertiser links?
    SO,CAL
    Re: Crazy Idle
    no
    Hondaisok
    Guest
    Re: Crazy Idle
    No, I just clicked on your link and Norton trapped it.
    Hondaisok
    Guest
    Re: Crazy Idle
    Tried it again and it killed Firefox. I'll scan my system-it may be something on it.
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    Re: Crazy Idle
    worked fine for me on firefox, with multiple virus protection programs going around.
    Mine was doing that, i tightened up the fast idle control valve screw, its on the top rear of your intake mani, then i adjusted my idle to idle lower.
    It only happens to me when its really cold out (35 or below)
    wprocomp's Avatar
    Armrest whore
    Re: Crazy Idle
    mine was the EGR valve, if you press the diaphragm from underneath the EGR it will usually stop until you let go-go get one from the junkyard or pay like hell for a new one,wait does your car even have an EGR?
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    Quote Originally Posted by wprocomp
    Yes this is on my 89 Lxi - my junker 88 LX has too many idle problems to even bother typing about.
    Also a heads up - I just aquired a 88 LXi coupe (w/ 5spd ) which I plan on swapping tranny into my LXi sedan. So since I will soon have three 3geezs I will be parting out my 88 LX sedan - I will put up a new thread when I do so.
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    OK Deadhead filled me in and said to try the following... but unfortunately this was not my problem - idle is still goin crazy.
    Thanks for the help though Deadhead.
    "Haha. ok, this took me forever to figure out, so be thankfull. j/k lol
    but on the rear side of the TB there is your Fast idle control valve. It's got a cover on the top of it held on with 2 screws. Take the cover off and you should hear rushing air. Put your finger in the center part of the black thingy in there, if your idle steady's out, then that's your problem.
    Take then a large flat head screw driver and turn that outer "ring" down until it's "snug"
    That should fix your problem, just put the cap back on and your set. I did this when I had my accord and drove it for a good 10k miles before I traded it in, and it never gave me anymore problems."
    Jul 2005
    Loveland, CO
    Re: Crazy Idle
    Did the idle change though when you put your finger in it?
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    No there was air whoosing through there - but there was no change when i blocked it with my finger - the idle still loped up and down.
    Re: Crazy Idle
    well, if your ECU doesn't give you any codes for EGR, than you should adjust Fast Idle Valve.
    It is easy to do. Remove the cover from the top of it (2 screws). start that car. get wide flat screw driver and turn it clockwise untill the idle levels. put everything back and you are done.
    you may have to adjust regular idle after the car will fully warm up.
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    Re: Crazy Idle
    wow this is just what my car is doing.... but i am getting the egr code... where exactly is the egr and how do i check it.. i looked in the haynes manual but that was not helpful at all
    LXi User oldschool3g's Avatar
    1989/Honda/Accord LXI HATCH
    somewhere in cali
    Re: Crazy Idle
    my car is kinda doing the same thing when i start it up cold in the morning it runs fine and feels fine...but it takes a long time to actually warm up to normal tempeture...and when it finally does..it starts vibrating..and jurking..not that much though...when it vibrates like crazy is when im stoped at a red light...its making me mad....can you guys help?
    Salem, Oregon
    Re: Crazy Idle
    Jeez, guys... You have to make sure that the coolant supply lines to the fast idle valve are clear before you go tightening it down. This problem is actually a result of a vacuum leak, somewhere. The Fast idle valve can cause the problem for various reasons. Low coolant level or plugged supply lines will cause even a good FITV to malfunction. A dirty throttlebody can keep the blade sticking open a little. A broken vacuum hose or leak in the intake manifold gasket can cause this too.
    LX User maxsideburn's Avatar
    1990 Honda CB7 Coupe, 1992 Eagle Talon TSi AWD
    Lafayette, Louisiana "The Hub City"
    Re: Crazy Idle
    Kabuki is right. When I first changed my thermostat and refilled my radiator my car was doing this. Just disconnect your battery for a few minutes, make sure you have plenty of coolant, then when you reconnect the battery and start the car up it will have a chance to "re-learn" how to run properly.
    Any FI car does this. In fact it's a good idea to "reset" your ECU fairly often, especially after doing any kind of work which could change the way your car runs.
    I read somewhere that marijuana effects the memory. Can't remember where I read that. -- maxsideburn
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    ok I have thoroughly checked out the coolant (filled it 100% including bleeding the motor), reset the ECU, and tried the 'thumb in the valve' technique. Still no resolve to my problem.
    I bought a vacuum pump tester tonight and found when I put vacuum on the EGR valve while idling (loping idle as always) the RPM smooths out and drops and the engine runs like ass. From what I know this means the EGR valve is good.
    Any more ideas?
    Jun 2005
    Columbus, OH
    Re: Crazy Idle
    PS i am not getting a CEL and I checked the ECU and I am not showing any codes
    Jul 2005
    Loveland, CO
    Re: Crazy Idle
    have you checked for vacuum leaks? take some carb cleaner to all of your gaskets and hoses on your intake manifold. If your idle changes when you spray in a specific area, then you know you have a leak there.
  1. idle gone crazy
    By AccordAerodeckEX in forum Carburetor Tech
    Last Post: 03-12-2004, 03:55 AM
  2. My idle went crazy today...
    By 87DXHatch in forum 3geez Accords
    Last Post: 08-01-2002, 05:17 PM
  3. Crazy Idle
    By DanG86LX in forum 3geez Accords
    Last Post: 07-12-2002, 02:23 PM
  4. CRAZY Idle problems
    By locknload68 in forum 3geez Accords
    Last Post: 06-28-2002, 08:22 AM
  5. Crazy idle
    By MiGRaNe in forum 3geez Accords
    Last Post: 05-11-2002, 09:26 AM
