Results 1 to 17 of 17
Thread: Torque Rod-Front Beam
    LX User 1989accordaz's Avatar
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Long story, but the center beam ( the crossmember that goes from the front beam to the rear beam under the engine ) is messed up. I need to replace it. Is it safe to drive without it? See link below, item number 1
    http://tinyurl.com/napvv
    In the meantime I need to find one at the junkyard.
    Thanks in advance for the advice.
    You are good...but I've seen better.
    1989 LX AT
    300,000
    Nov 2002
    Ridin Dirty in New York
    Re: Torque Rod-Front Beam
    no
    LX User 86-accord-lxi's Avatar
    ^My other asian body^ 1989 4dr lxi
    OKC
    Hmmm... I would't think It would cause any problems mechanically, But I wouldn't recommend driving without it, at least if you don't have to. Especially on the highway ! That beam supports the structural integrity of the car. Definetely an imporntant part!
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    when i got my car mine was all rotted out... i went to like rockauto.com or something dont remember exact place...and got one for like 150 after shipping...
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Thanks for the replies. I will not drive it until I replace it. I guess I needed a second opinion to save me from my own stupidity.
    $87.00 before shipping. I'll check the local junkyards.
    Thanks
    1989 LX AT
    300,000
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    I've had pretty good luck here.
    Arizona U-Pull & Save Auto Parts
    5602 N Camino De La Tierra
    Tucson, AZ 85705 - 1011
    Bring your tools and $1
    There's a huge place that's usually even cheaper in Phoenix at 3250 W. Broadway.
    Mike
    shepherd79's Avatar
    Falling Waters, WV USA
    actually, you can drive just fine.
    Nov 2002
    you most certainly DO need that part
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Quote Originally Posted by AZmike
    Thanks, I bough the part before I read your e-mail. I bought it for 30 dls at parts for less. That was the cheapest from the ones I called and the closest one from work.
    Parts for less
    5151 S Swan Rd
    Tucson, AZ 85706
    1989 LX AT
    300,000
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Check the rubber mount that bolts on to the lower part of the bellhousing. The mount sets in the bottom crossmember. It helps on unwanted stress on the front & rear motor mounts under torque along with the dog bone (top) motor mount.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Then I guess everyone with B-series swaps are screwed cause none of us have it. It doesn't work with the B engine in there. Mine has been out for almost 2 years and I've never had any problems.
    Nov 2002
    b series mounts are hugely different and b series engines do not need it. Why you need it is because that mount plays a large role in keeping the engine rocking from side to side in the engine bay. Without it, sooner or later whats gonna happen is youre gonna turn a corner and have either the axle fall out of the transmission or the inner cv joint come apart on you
    shepherd79's Avatar
    You don't need it. It is not structural. All it does is supports the engine to help reduce the load on the front and rear mounts.
    I know for the fact that on both of my accords, the rubber on the bottom of the tranny didn't even touch the crossmember.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    So you're saying with 4 other mounts, there's enough play to tear up your axles? I find that hard to believe. I helped put a new clutch in a CRX the other weekend and we had the motor held in with the 2 side mounts before we tried putting the front and rear in. We could barely push the engine around to line the bolts up for the others. We needed a pry bar.
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Here is the story: I replaced the steering rack 3 years ago, and I removed to center beam to do so. But once I put the rack back, the holes for the bolts on the front end of the beam didn't quite lined up with the holes on the frame. So what did I do? I left the front bolts off.
    So for 3 years I have been driving with only the rear part of the beam bolted onto the frame. But now that is completely out of the car, I just don't want to drive it. I figure I have been pushing it for way too long, it's time for me to take care of my baby!
    It's almost at 200K. But the tranny and engine are the original though.
    1989 LX AT
    300,000
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Try this. Don't tighten one side to tight. Leave the bolts just started in the threads about 2 turns on one side, then try to start the bolts on the other side.
    Edit- Happened to me when I tighten one side of the crossmember to tight.
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Talking Re: Torque Rod-Front Beam
    Well, the center beam from the junkyard did the trick, it did fit. Thanks all for your input.
    1989 LX AT
    300,000
  1. help - rad rod/front beam. hermiston , oregon
    By vongiese in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-25-2007, 10:04 AM
  2. Extra holes in the front beam
    By carotman in forum 3geez Accords
    Last Post: 09-30-2006, 05:52 AM
  3. Effects of Lowering front beam ?
    By A20A1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-15-2005, 10:34 AM
  4. Tubular front beam idea
    By AccordEpicenter in forum Performance
    Last Post: 03-21-2005, 05:48 PM
