Results 1 to 3 of 3
Thread: Warm Up Idle
    Hondaisok
    Guest
    Warm Up Idle
    When cold starting(below freezing) my 87 LX carbed, goes into what I believe is the 2nd stage, about 1200 rpm for maybe 5 minutes, then goes up to 2200-2500 rpm(3rd stage?) until engine warms up to normal. I believe this is the opposite of what it should be. If so, does anyone have an idea what could be the problem? I keep thinking it will die while I'm scraping the windows.
    It is more of a nuisance at this point, but something must be out of whack.
    Thanks.
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    Re: Warm Up Idle
    Try hitting the throttle a little when you first start it and see if the idle stays up?
    -Harvey
    Hondaisok
    Guest
    Re: Warm Up Idle
    Yeah, I've tried revving it up several times, but it drops back to about 11-1200 until something warms a little, then goes up to 2200 or so. The weather is warming up, so I'll see what happens. Thanks for your help.
  1. Car sometimes won't get off warm-up idle
    By jzdude in forum Carburetor Tech
    Last Post: 05-29-2012, 08:59 AM
  2. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
  3. Warm idle adjust?
    By agelder in forum Carburetor Tech
    Last Post: 05-24-2003, 07:49 PM
  4. is there a way to lower my fast idle, but keep warm idle the same?
    By bobafett in forum Classic Honda Community Chat
    Last Post: 03-20-2003, 05:44 AM
  5. Warm up idle?
    By jteuton in forum 3geez Accords
    Last Post: 10-15-2002, 10:17 AM
