Results 1 to 6 of 6
Thread: help before i go crazy
    .....my fender....how in the hell do you remove it?ive got all the bolts on th top from headlight back.the two bolts on the in side of door. the bolt on the bottom. the bolts in the wheel well where else?? help
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Re: help before i go crazy
    You have to take your front bumper off. There is a bolt or 2 behind there.
    Where Are Nuts At?
    Is It Behind The Turn Signal Or Do I Have To Remove That
    I think it's behind the turn signal. I don't remember. Be careful taking off the turn signal. The plastic on it is very brittle and snaps easily.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Pull out the fog light covers and then look up toward the turn signals. You'll see 1 screw on each one that you have to loosen. The screw doesn't come the whole way out. Loosen it and then pull the turn signal out. There will be 2 bolts behind each one holding the bumper on. Take those out and the bumper slides right off.
  1. Crazy kids and thier crazy....JP's
    Last Post: 10-23-2010, 07:06 PM
  2. this was crazy
    By AccordArizona89 in forum Classic Honda Community Chat
    Last Post: 11-16-2003, 08:30 PM
  3. Going Crazy!!!
    By jlaccord89lxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-04-2003, 02:08 PM
  4. am I crazy???
    By HondaLuxury in forum Classic Honda Community Chat
    Last Post: 05-01-2002, 11:14 PM
