Results 1 to 6 of 6
Thread: Charging System Problems
    Okay, my cars battery kept dying on me. When i was driving with the heater on high...the radio would cut out, headlights dim. So i went and bought a new alternator, put it in and still seem to have problems. I put a tester on it and it is testing 12ish....to low. It never gets higher than that. I took new alternator back and got a new one.....same problems. All my fuses are good and so is tha battery. How do i bench test an alternator and what do i do to solve my problems......
    89 lx
    LX User 1989accordaz's Avatar
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Re: Charging System Problems
    Is your battery light coming on?
    Have you had your battery tested?
    You have repalced your alternator twice with new ones, chances are that the alt is not the problem. Have your battery tested at any autoshop, and try it.
    You are good...but I've seen better.
    1989 LX AT
    300,000
    LX User Swap_File's Avatar
    Manual 89 Se-i Accord
    Minnesota
    When I got my free 1989 Accord the previous owner had replaced the battery and alternator, and still couldn't get the car to keep a charge.
    Turns out the alternator cable just needed to be re-crimped. It worked fine after that.
    Quote Originally Posted by Canadian67
    89 lx
    Your on the right track it should be about 14v volts running and a good charged battery at rest should be 12.7v. if you have an amp clamp you can check for its amp output as well.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    the alternater needs 12vdc from the battery to create a magnetic field. If the wire from the battery to alt is not connected properly or broken, it will not produce voltage. I think SWAP FILE mentioned this.
    Quote Originally Posted by Blkblurr
    yeah if the field wire is not excited it wont charge. I just dont know which one it is on our cars so I didnt mention it.
    Good point.
  1. Charging system, and some other issues
    By zenapup in forum 3geez Accords
    Last Post: 01-16-2013, 07:23 PM
  2. charging system help
    By beran24 in forum 3geez Accords
    Last Post: 11-12-2010, 01:26 PM
  3. ....Charging system problem
    By Ayeobe in forum 3geez Accords
    Last Post: 11-13-2009, 09:48 PM
  4. Charging system HELP!
    By Ajbent86 in forum 3geez Accords
    Last Post: 09-02-2008, 01:50 PM
  5. Charging System Problem
    By syphrvirus in forum 3geez Accords
    Last Post: 08-13-2004, 11:32 AM
