Results 1 to 2 of 2
Thread: Probably a stupid question....
    LX User EducatedFool's Avatar
    How do I add gear oil to my manual tranny? If it helps any, I have an 86 DX hatch. I've never worked on a manual car before so i have no clue where to put in gear oil. thanks
    LX User Shadowkat's Avatar
    1989 Accord LXi auto-->5 speed conversion 250,000 mi!!!! and still kickin!
    Champaign, IL & Chicago, IL
    Re: Probably a stupid question....
    Quote Originally Posted by EducatedFool
    There's probably a post somewhere else on this topic. But if you searched for it and couldn't find anything. . .The plug to fill the manual trans. is on the passenger side of the tranny near the top. The plug is giant, but it can be removed by a 17mm socket wrench i believe. You will need approximatly 2.5 quarts of mtf(i recommend genuine honda mtf) to fill the trans from empty. Remove the plug, then use a funnel with a hose attatched to the end and pour the fluid in(it's quite viscous and wil probably flow slowly). Once you are nearing 2.5 quarts(i recommend starting this part after just 2 quarts to be sure), put your hand or some fingers under the opening where you fill the trans, and once you feel the fluid start to pour out onto your fingers you know the trans is filled.
    If you have not done this before and need to drive your car, i suggest getting some help, otherwise it could take a while to find the plug and whatnot. Also, i suggest buying a chilton's manual or a factory service manual to help with routine maintenance things like this. And next time try searching, because there is probably a thread already posted on this. Good luck!
    The winter beater--I pulled the spoiler off a civic"
  1. stupid question but...
    By chiller670 in forum General Engine Swaps
    Last Post: 11-10-2006, 10:31 PM
  2. another stupid question
    By Tha Realist in forum 3geez Accords
    Last Post: 01-27-2005, 04:44 PM
  3. Stupid Question
    By RobbyKlotz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-20-2004, 06:55 AM
  4. very stupid question to be asking
    By 3rdGenMartyr in forum 3geez Accords
    Last Post: 11-18-2002, 11:07 PM
  5. this may be a stupid question.. RE: Gas
    By Maydnaella in forum Classic Honda Community Chat
    Last Post: 11-09-2002, 08:38 PM
