Results 1 to 24 of 24
Thread: H4 Headlight
    Mar 2006
    '88 Accord LX-i Coupe
    Byron, Georgia
    H4 Headlight
    Hey Guys. I'm planning on putting some headlights on my '88 LX-i, and I'm wondering whether or not I should install relays in my light circuitry (to avoid overheating the wiring and to avoid arcing in the switch). What is the highest wattage that the factory switch and wiring can take? I'm planning on using 80/100 watt bulbs (I know that these arn't street legal, but I've had 'em in my truck for almost a year and no tickets yet). I 'preciate the input in advance.
    -Mark
    Jun 2001
    Boston MA
    Re: H4 Headlight
    dosent hurt to wire it right. iven seen many light sockets get burned out.
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Nov 2000
    Re: H4 Headlight
    The main current draw for the headlights does not go through the switch. The switch actuates a set of headlight relays that are in the fuse box under the hood. I calculated the maximum current draw on the relays and they can take the 80/100W bulbs. With that said, I do believe there is some wiring in the dash that can get too hot. When I was using a set of 90/100W bulbs I would occasionally smell overheated insulation and my dash clock would reset itself to 12:00 randomly. The issue went away when I switched to 55/60W bulbs.
    80/100W bulbs do not get you proportionally more illumination. They put out maybe 25% more lumens than 55/60W bulbs. A further disadvantage is that they last half as long. If you are going to use them I would definitely add additional relays to the headlight circuit so that they pull their current directly from the battery.
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    Quote Originally Posted by DBMaster
    Very detailed answer, I really appreciate it. I'll probly just go with the 55/60 bulbs then, since I wouldn't have to do any additional wiring. I appreciate the advice.
    Re: H4 Headlight
    well i just did mine but i bought the warness from some one here if u can get a hold of the harness its really not that bad of an install and i really do like the h4's over the stock seald beam's
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    Wouldn't the connections be the same? I did it on my truck that had the same style sealed beam lights and the H4 bulb had the same connector on the back as the sealed beam light...or did you mean to add the relays to the circuit?
    -Mark
    Re: H4 Headlight
    ya to add the relays
    it just pluged into one of the existing lights and the went the battery and then grounded and it had the new relays in it it was rather easy i belive u can buy then pre assembled im just not sure were
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    That sounds pretty kool. I might look for those...I saw a few on summitracing.com, but I didn't really look at them, they might be what you're talking about. I just thought they might be ones to adapt one plug style to the H4 style, but they might have relays built into them. 'Preciate the input.
    Re: H4 Headlight
    do u have housings already
    if not i would say the autopals i got are vary nice
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    I found some that're $13 a piece at summitracing.com, but I havn't ordered them yet.
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    I found the wiring kit...
    Re: H4 Headlight
    dont order cheap housings they look good asthiticly but the light output sucks
    get these http://cgi.ebay.com/ebaymotors/200mm...7800QQtcZphoto
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    Re: H4 Headlight
    I sold mine to ghetto........this is the seller, you don't have to get them with the bulbs though.
    http://cgi.ebay.com/ebaymotors/H4-WI...49197728QQrdZ1
    And all you need is the h4, don't matter what car its for.
    ~Ryan~
    Re: H4 Headlight
    man and i gave u $35 hahahaha its cool though
    Jul 2004
    wa
    Re: H4 Headlight
    Yeah, with shipping those are like $50. Because they make you insure it coming from China and all.
    ~Ryan~
    Re: H4 Headlight
    shipping was only $20 so 40 and i could of got a new set man i got jewed lol j/k
    still got um 5 bucks off
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    Another thing...wouldn't the headlight out light on the dash come on if I wire it with relays? How would I stop this, just take the light out of the dash?
    Jul 2004
    wa
    Re: H4 Headlight
    Quote Originally Posted by mgardner
    No, it won't. You use you original plug as the activator for the relays, so it installs and activates the light as if it was factory.
    ~Ryan~
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    Ryan, where are the pictures of your car on that link? Or are there any?
    -Mark
    Jul 2004
    wa
    Re: H4 Headlight
    -Mark
    No, none of that. If you get one of the kits, or wire relays yourself, it is really easy to wire. I would suggest just buying one of the kits. It is much easier that way, you just plug and play, it comes with instructions too.
    ~Ryan~
    Banned
    89 Honda LX
    Beertown, USA
    Re: H4 Headlight
    Also, most of that is BS. See here:
    http://danielsternlighting.com/tech/...uperwhite.html
    Mar 2006
    Byron, Georgia
    Re: H4 Headlight
    Quote Originally Posted by 3gn86lxi
    Nah, I meant I just wanted to see your ride, isn't that it on your avator? It looks pretty sweet.
    Jul 2004
    wa
    Re: H4 Headlight
    Oh. Here, refer to this post.
    https://www.3geez.com/forum/showthread.php?t=49926
    ~Ryan~
  1. Very Dim Headlight
    By lamontlamont in forum 3geez Accords
    Last Post: 02-01-2006, 01:33 PM
  2. Headlight help
    By whyterice in forum Interior & Exterior Care
    Last Post: 01-17-2004, 09:28 AM
  3. headlight
    By Chadroper in forum 3geez Accords
    Last Post: 11-11-2003, 02:04 PM
  4. Ack! Need Headlight Help!!!
    By 3G Jester in forum 3geez Accords
    Last Post: 09-09-2002, 09:59 PM
  5. Right Headlight Is Dim
    By ‹^› ‹(•¿•)› ‹^› in forum 3geez Accords
    Last Post: 09-04-2002, 03:09 PM
