My wipers all "work" but the windshield ones dont remember where the bottom is. Ill hit it once so it goes and wipes once, and sits back down, but as soon as I let go of the button it stops, so they will stop half way through. Same goes with the sprayer. instead of going by 3 times, its like 2 and 1/3 or wherever it decides to stop.
And the rear wiper only has about 25% of movement. I put it to the bottom resting position and ill use it, itll go all the way up and come back down 25%, it sounds like it tries to move more, but then it goes back up, then down 25% again. Only way to get it down is to physically move it down.
Any ideas what could cause either problem? The rear wiper seems to be a motor/gear problem.
I havent looked in depth, but there is clearly no wiring problems or anything physically in the way to cause these behaviors.... is it simply just a new switch for the front ones?
