Results 1 to 11 of 11
Thread: Thrust washer?
    Idaho
    Thrust washer?
    So what do thrust washers do...they are on the middle crank journal?? If I'm changing the rod bearings and main bearings, should I change the thrust washers?
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Thrust washer?
    It keeps the crankshaft from forward or backward movement. I would replace the thrust washers, since you got all new parts in there. You can mount a dial indicator on the end of the block, put the tip of the indicator on the end of the crank, pry back & forth on the crank to determine if the play is too excessive.
    Idaho
    Re: Thrust washer?
    Is there just one size of thrust washers?
    SEi User B16KILLA's Avatar
    SO,CAL
    Re: Thrust washer?
    Thrust washers are used to control crankshaft endplay, They do sell them in different sizes oversized and undersized. If you've had your crankshaft bearing journals align bored then I'm pretty sure you'll need the undersized bearings, it might sound weird but its backwards.
    Idaho
    Re: Thrust washer?
    Coolio THanks!
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Re: Thrust washer?
    With the main bearing caps on & thrust washer installed. The only good way to find out the tolerance on them is to use a dial indicator monted on the end of the crank & pry back & forth. Since the dial indictor is a little pricey.
    You can leave the 3rd main bearing cap off & all the others installed. With the old thrust washer in the top side of the block. (Block would need to be out the car & upside down) Pry the crank forward, stick a feeler gauge in between the thrust washer & connecting rod. That will give you close measument of thrust bearing wear (end play) without buying a dial indicator.
    New standard size thrust washers should be suffecient enough if you ask me.
    Idaho
    Re: Thrust washer?
    I've got the block outa the car and on a stand btw. So yah, i think i'll get all standard bearings. I already plastigaged the rods and mains...
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    Re: Thrust washer?
    i hate to bump up this old thread, but does anyone here know off the top of their head, which way the thrust washers supposed to face? there is one side with a groove, and one side without. the manual i have doesnt say anything about that.
    Idaho
    Re: Thrust washer?
    Groove faces the inside I think?
    SEi User
    Jun 2005
    Edmonton AB
    Re: Thrust washer?
    can you put it in a perspective as in the thrust washers face each other or dont face each other? sorry for my semi noobness, its been over a year since i rebuilt an engine
    SEi User
    Jun 2005
    Edmonton AB
    Re: Thrust washer?
    anyone?
  1. LED Washer Sprayers...
    By 89accordlxigentyers in forum 3geez Accords
    Last Post: 02-23-2011, 07:58 PM
  2. washer squirters
    By import racer in forum 3geez Accords
    Last Post: 02-17-2009, 09:42 PM
  3. washer trick
    By 89sei89dx in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-23-2008, 01:31 PM
  4. thrust washers
    Last Post: 10-17-2006, 07:53 PM
  5. Washer Trick??????
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-25-2004, 12:40 AM
