Results 1 to 4 of 4
Thread: Axle swap info
    Ichiban's Avatar
    North of You.
    Axle swap info
    As promised, here are the charts regarding the info on the bearing swap to accomodate the Se-i axles with an A20 engine/tranny swap.
    well, do i have a reply for you....
    In some other thread i spoke about going to the bearing place and doing some cross-referencing. Well, here's how it goes: (Federal Mogul bearing #'s)
    Bearing B-32, (36mm bore, 2.8363'' OD, 34mm inner/outer ring width), fits 81-87 Prelude (exc Si), 81-85 Accord (exc SE-i)
    Bearing 513025 (38mm bore, 2.8362'' OD, 34mm inner/outer ring width), fits 85-87 Prelude Si, 84-85 Accord SE-i
    Bearing 513053 (40mm bore, 2.9937'' OD, 41mm inner ring width, 38mm outer ring width) fits 86-89 Accord.
    As you can see, the 2g and 3g bearings are quite different, but the 2g and Si/SE-i bearings are identical, except the 2mm difference in the bore (ID) that will allow us to run the SE-i/Si drive flanges. changing the knuckle won't be needed; just change the bearing and flange, now you can run the bigger shafts to accomodate your engine swap! I'll be checking part #'s to see if the prelude Si and Accord SE-i flanges are the same (which i think they are). If so, Prelude Si's will provide a ready source of the oversised flanges, as they sure are a hell of a lot easier to find than the Accord SE-i's are.
    Another solution would be to have the 3g flange machined down the 2mm so it fits. i wouldn't want to machine it down 4mm to the original 2g bearing size
    The Federal Mogul Bearing Application Chart
    The Bearing Dimension Page
    ICHIBAN!
    "Now, even more better!"
    Jul 2004
    85 Accord ES2
    Neosho, MO
    Re: Axle swap info
    so in lamens terms that means that the lude shafts would be better than the SE-i shafts id guess. is this for the basterd shaft mod or they fit in perfectly stock with teh a20 in teh 84/85?
    PhydeauX's Avatar
    Eastern Penna
    Re: Axle swap info
    This problaby belongs here in the faq. Just for reference this pertains to changing the bearings in a carbed 2g so you can use 2g Prelude Si drive flanges so that 85 Accord SE-i axles will fit. The 85 SE-i axles are plug and play with a 3g, lude 2.0, or Teg Hybrid (using the teg diff center) trans swap into a 2g accord.
    andy
    Re: Axle swap info
    Just out of curiosity, and for the record, why do some of the OD on some of those bearings have "--" instead of MM?
    Is that because, for example with bearing B32, 2.8363 inches is 72.04mm? Is 0.04mm enough of a difference in tolerance, that you wouldn't want to press a 72mm bearing into a 72.04mm hole, or vice-versa?
  1. swap info A18
    By bakedboarder34 in forum Performance
    Last Post: 07-22-2007, 10:32 PM
  2. Axle swap info
    By Ichiban in forum 2geez Tech & Performance
    Last Post: 03-29-2006, 10:26 AM
  3. Tranny swap & axle question
    By QuickToy in forum General Engine Swaps
    Last Post: 01-28-2005, 10:02 PM
  4. I need a Driver's side axle and pedals (5 speed swap)
    By BITESIZE in forum Trading Post
    Last Post: 08-02-2003, 09:04 PM
  5. b20 swap axle
    By BOLINKXR-89LXI in forum General Engine Swaps
    Last Post: 01-05-2003, 01:01 PM
VigLink badge
