The history:
I swapped a 87 LXI A20A3 into a 89 LXI (this LXI also had A20A3), I used the harness and intake manifold from 89 LXI. I have dropped the engine back in reconnected everything, vaccum lines are in. It has trouble starting, at first nothing and I found ground was off. Now it cranks from ignition (was only positive to starter before), but it rarely turns over. It has a couple of times turned over for a bit and rpms fluctuate between 2k and 3.5k then stalls. Since it then would not start again when cranking, I checked plugs (firing order is 4321 correct?) and tested plug on far left by grounding, had spark. Put back in and it started everytime for like an hour but still fluctuated rpms. Now I am back to just cranking (distributor was swapped to 89 model.) Now battery is also dieing, left on over night and died. No light were left on.
What are yalls suggestions? I have the manual and have learned most of the part locations? But please provide me with idea of where part is with your testing suggestions. I hope I am not really shit out of luck. Tell me this swap was ok, can I be facing a wiring harness mismatch problem, or vacuum lines or something.
Let me know thanks!!!!
