Results 1 to 5 of 5
Thread: hub wobble (really bad)
    1988 dx
    ok hers the problem, the front driver side wheel has had a bad wobble in it for like two weeks now, so when i finally got the urge to fix it i jacked both sides of the front end off of the ground, took tires, calipers and my rotors off started the car put it in first and i can actually see the hub is out of round. so i am thinking its the bearing/hub assembly(btw no cracks in the hub) just wanted some more insight on this and the tools i need to take it off so i can bring it to a shop to have them press the bearing.
    88/accord/LXi
    sunny 'ole florida...
    Re: hub wobble (really bad)
    yes its the hub...
    i just replaced my driver side bearing like 5 days ago....its really a bitch to take in and out, we did it our selves because there was no one open to press the bearing in the hub....
    also the tools required, if you put it in yourself, hammer and block of wood...have you got the bearing out??? if not we had to take the bar that the tire and such connects to out....that took a bit of time...prob 1 hour, the actual tools used....3/4 breaker wrench/arm, hammer, block'o'wood...i dont remember the actual socket eizes and such that i used...
    the whole procedure took about 3 hours...and the wheel bearing was about $40 from a place called eastern imports...
    -------88 lxi sedan--------
    -rebuilt engine, ground up-
    -custom built short ram 3' pipe-
    -straight pipe exhaust with 3Aracing muffler-
    -weight reduction-no AC, no cruise control, other things such as removal of covers,etc...-
    -head regrind..lol-
    1988 dx
    i figured it would be a bitch to take off but thats the only option i have, also while i am in the process of all this crap i plan on changing both bearings, upper and lower ball joints, and all bushings. prolly take me a while but its worth it.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    ^^ I;m iun the same boat, getting a pretty bad wobble, and I can tell my ball joints are on the way out... I should really get on that and order some parts...
    1991 Civic STD
    Arbutus, MD, Baby
    A slide hammer's going to be a wise investment.
    Daily Drivers Done Right
  1. Wobble Sound
    By vteckiller in forum 3geez Accords
    Last Post: 02-27-2012, 03:59 PM
  2. Death Wobble?
    By *-=Duckumz=-* in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-30-2010, 11:27 AM
  3. steering wobble
    By 1987HondaAccord in forum 3geez Accords
    Last Post: 01-05-2005, 08:33 AM
  4. Wobble
    By MrBen in forum 3geez Accords
    Last Post: 03-24-2004, 12:20 PM
  5. low speed wobble
    By Dallas&SarahsAccord in forum 3geez Accords
    Last Post: 12-06-2003, 06:51 PM
