Results 1 to 10 of 10
Thread: n00b Q about crank pulley
    where abouts is that little hole in the crank pulley when its at TDC?
    LX User 86-accord-lxi's Avatar
    ^My other asian body^ 1989 4dr lxi
    OKC
    Re: n00b Q about crank pulley
    You can view the timing marks and TDC marks on the flywheel between the transmission and the engine block, (Kinda under the distributor) For automatics the TDC mark for cylinder 1 is kinda of by itslef and has a mark underneath it that looks like a sideways T. The little needle indicator on the block should be "dead on" the tdc mark, which us usually white, unless it's not white like mine ! There should be the word "up", and two timing marks on the cam pulley, The "up" should be up at the top, and the timing marks alligned parallel with the top surface of the head.
    oh yeah, i didnt think of the cam pulley, thanks
    I dont think the little hole is at 12 o clock. Im thinking its more like 1 o clock or so. Duddec juts rebuilt his motor hopefully he will chime in or you can PM him about it.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    The peep hole is on the housing that the manual transaxle or tranny bolts on too. There is some red mark your supposed to look at. Good luck finding it. I set base timing with 2 the vacuum hoses plugged & timing light hitting the "T".
    Look for the "T" on either the flex plate or flywheel to set TDC on #1 piston.
    If your going to break the the crank bolt loose, read some other posts I mentioned about some techniques..
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    nah i was just wondering coz the belt tensioner sumhow got very loose, and wen i tried starting it, it sounded like the motor was spinning a bit fast, i thought the starter was effed, but goes fine, the belt just came loose and i just needed 2 know what position the crank should be at to put the belt back on, this is on the other car b4 i tipped it
    like this?
    does it have to be exactly perfect? does it really matter if it was a couple of teeth out?
    BUMP!!11@!eleventywonupsidedowneye!11atsignbyaccident
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    The "T" is facing to the left when it hits the pointer. I'm not sure what is going on with them diagrams you got there. You can't be a couple teeth off on anything. It has to perfect when you install everything.
    Edit- also look at the crankshaft keyway. It should point at 12 O'clock & the camshaft sprocket word "UP" facing 12 O'clock..
  1. Crank Pulley
    By Hick in forum 2geez Tech & Performance
    Last Post: 03-13-2010, 06:49 AM
  2. n00b Q about crank pulley
    By A18A in forum Classic Honda Community Chat
    Last Post: 04-06-2006, 06:01 AM
  3. crank pulley
    By john in forum 3geez Accords
    Last Post: 06-30-2005, 10:14 PM
  4. Help can't get crank pulley off!!!!!
    By kevins89lxi in forum 3geez Accords
    Last Post: 08-24-2003, 07:17 PM
  5. crank pulley
    By jteuton in forum Performance
    Last Post: 05-26-2002, 07:34 AM
