Results 1 to 16 of 16
Thread: Cables
    Jul 2002
    88 Accord (Australian Model Si)
    GoldCoast, Australia
    Cables
    hey everyone, whats happening?
    Anyways - i was looking for the thread which had guage sizes in it. But i was unable to locate it. SO here;s my question:
    Can someone detail the different guage sized cables to me?
    I was wondering if i could run a 8 guage wire from the positive terminal on the battery. and use a 6 guage wire to ground? SOMEONE PLEASE HELP!
    LX User catalin's Avatar
    1986 Accord Hatchback
    Surrey, BC, Canada
    Re: Cables
    You should use the same gauge of cable but for the application that your asking about 6ga is bigger than 8ga so you can do that. Also it really all depends what you are using to run off that cable. If its something like a small weak amplifier that will never draw more current than 15amps then 8 and the 6 gauge cable is overkill. On the other hand if you're using a large amp(s) for your whole system then you should go with 4gauge.
    You should be able to find more detailed info at www.meisearch.com
    shepherd79's Avatar
    Falling Waters, WV USA
    i would say just to make sure that you don't loose anypower from battery to your amp, use no less than 8G. i have 4G and i am running 4 channel and mono amp on it. it seems do ok for me.
    plus don't forget to run it on the other side of your car or you may get electric noices.
    oh yeah and if you have extra money upgrade the battery lamps with gold plated. they don't corrode, easy connection for your amp, and they look a lot better.
    Jul 2002
    Thanks fellas.
    The amp i'm using is a 360W or 180W RMS. I'm using it to run a 12" Phoenix Gold (200W RMS). basically it should run it perfectly.
    So, it is alright to run 8 guage from the battery to the amp. And then use the 6 Guage as ground?
    SEi User gr3k0sLaV's Avatar
    Feb 2002
    1998 VT Commodore 50th Anniversary Edition
    Geelong, Australia
    Thanks fellas.
    4 gauge from the battery, to a distribution box, then 4 gauge to the amps.
    Remember an inline fuse between the battery and dist box.
    That's how ive got it.
    Cocaine's A Helluva Drug! - Rick James
    I really fracked things up for you Bill - Colonel Tigh
    Girl we couldn't get much Higher! - Light My Fire
    shepherd79's Avatar
    Thanks fellas.
    yeah you should be good. good luck.
    Jul 2002
    You guys better be right, I don't wanna blow anything up!
    Jul 2002
    1986 Honda Accord LX-i Hatchback
    Malvern, AR
    You wont, you will be fine. 8 gauge is plenty for that setup.
    Trust in God but lock your car
    Jul 2002
    but its 8 guage in, 6 gauge out!
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    its better than 6in and 8 out
    Jul 2002
    yeah i know.... but i'd rather it be the same.... just following the general rule..
    2005 Mazda 3
    Ontario Canada eh.
    i know i know, but your safe with that setup. I'm runing a 4g to a block then a 8g to power a 300w mono sub amp powering 2 12" 250w subs, i just planned for more amps
    Jul 2002
    nice one
    Jul 2002
    i hope my box works....
    It should be finished by friday.... I build her real nice..
    Jul 2002
    built rather than build
    Jul 2002
    She's good, and pumps hard...
  1. disconnecting the heater control cables
    By RoseCity Lxi in forum 3geez Accords
    Last Post: 03-14-2009, 06:36 PM
  2. I need help replacing Battery cables
    By 314lxiSleeper in forum EFI Tech
    Last Post: 12-15-2008, 10:48 PM
  3. grounding cables
    By pervasto in forum Performance
    Last Post: 07-02-2004, 11:08 AM
  4. sei 2door ebrake cables for sale or trade
    By neoblue89lxi in forum Trading Post
    Last Post: 03-08-2004, 07:22 AM
  5. where should I run my cables??
    By AD9SloAccrd in forum Interior & Exterior Care
    Last Post: 05-09-2003, 06:38 PM
