So I go to Auto Zone and get two reman CV shafts to slap in. I spent alot of time yesterday putting those in, along with a new alternator and some gaskets that needed replacing. Get it all back together and checked over to make sure all the suspension fasteners are tight, and go for a test drive. Two miles from the house the driver side axle gives out, busts out of the knuckle cup by the transmission. Dammit. Find out the axle was too short by about 1.5". I thought they just put the wrong axle in the box. After alot of researching, we came to the conclusion my car uses a STANDARD SHIFT axle, which is, about 1.5" longer than the AUTO SHIFT axle. WTF???? So, I had to go out to the parking lot where I rolled my car to and pull the new broken axle out, and returned it to AZ, got my factory axle back, and took it to a good driveline shop to have it rebuilt.
Has anyone come across this before? They said that the OD 4sp Auto and the Manual transmissions are thinner and the shaft for those are longer, and the 3sp Auto is thicker and that the shaft their computer calls out for is probably for that car, but it does not say specifically for 3sp or 4sp or give any dimensions of the part.
What a mess........![]()
