i seen a old thread on there where someone mentions an oil driven turbo, so what about somthing thats hydraulic, like using the ps pump to turn somthing.
there is massive psi behind that puppy. what are ye thoughts.
That certainly would be interesting, but keep in mind that rubber seals tend to be specific to what kind of material they are in contact with. It will break down, enlarge.... all sorts of wierd things can happen.
I don't think it would be the smartest idea IMHO, but it's definatly an interesting thought.... anybody else have thoughts on this that is smarter than me? lol
well as far as i know the power steering in alot of these cars get used aloot and never have to be maintained as far as i know, just check the fluid, i could be wrong but i never had to anyway.
Are you sure the person did not mean oil cooled? I have never heard of a turbo being spun by hydraulic pressure alone.
He may have been saying that he had specifically an oil cooled turbo, versus some other turbos which are cooled by both oil and water.
You could maybe have a pump driven by the engine make hydraulic pressure to drive another hydraulic motor which would turn a supercharger. It could work, but would probably be a lot of work. And you would lose energy in the pump and hydraulic motor.
I once had a crazy idea of using hydralic pressure to drive back wheels (like hydrostatic drive in some lawnmowers and tractors), but I do not believe it would be efficient beyond 30-40MPH.
No i didnt misread anything, i was just thinking after seeing the oil driven turbo thead, that if it would be posible to make one that runs off the ps pump or a diferent hydralic motor.
I figure the ps pump because it already has to work to turn the wheels, so for people who dont want power steering, to give it a new task, running a sc/turbo
Gives me somthing to think about, im probably crazy to even think about it. lol
Originally Posted by Vector
heheeheh yea i need some of those to go with some of my crazy ideas, cuz then they would never happen, in turn i live longer
rofl at least you are a good sport about it! hehe
maybe a crazy idea, but at least your thinking, thats good
\Originally Posted by Vector
the closest one is an air driven pneumatic turbo. Works off of a compressed air chamber. Not really ideal. but its something made to work. It all comes down not to the ability to work, but the efficiency of the product and the long time profit of it. for now, ill stick with the conventional turbo design.
Alfa Romeo used an oil driven turbo.
well i dont know if using the ps pump would work, when you said it would be easy to use since some ppl run without ps but the only reason i would unhook ps is to gain some free power, without the motor having to turn the pump you would then gain "free power" but if i unhook it just to hook it back up for a turbo it seems kinda pointless to unhook it , well for me anyways. i guess if you were to add another ps pump, that might be better
-Who needs horse power when you got icy roads and bald tires
-To drift a car is to create reckless art
To optimize the efficiency of the power transfer, the hydraulic pressure would have to be very high with very low volume, and the hydraulic motor itself would be geared at a high ratio to the shaft of the compressor. The advantage to this would be instantaneous, controllable boost at virtually any rpm. I believe it is likely these will become commonplace in the future.
2 more points: 1, the pulley drive system for the p/s pump cannot transmit the kind of power required for this setup, and 2, the centrifugal compressor would have to be properly sized to the application, so you wouldn't surge it at low engine speed. You don't run into this problem with a big turbo on a little engine because you also have a big turbine that doesn't spin the compressor fast enough at low engine speed to surge it. The hydraulic pump could spin the compressor as fast at 1500rpm as the turbine wheel could at 4500.
oh well, was an interesting idea. thanks for shooting it down.
lol
It was a Centrifugal supercharger.
Originally Posted by http://www.autocomponenti.com/tech.htm
a centrifugal supercharger compressor works in the sampe principle as a turbo compressor. hence the centrifugal supercharger has its own flow charts. they dont spin that fast. so i guess hydraulics can drive it in contrary to the turbo that spins at 300,000 rpm and more.
I'm not sure I follow you. Yes we remove the PS because it robs HP from the engine and makes the car weigh less, but if you can use it for FI it's the same principal as a Supercharger, being driven by the engine requires some power, but the gain in power from forcing more air and fuel into the engine is worth it.Originally Posted by b8er
well, I think the speed of the actual compressor itself, the shaft rpm, could be just as high as a turbo. It's all about the gearing between the hydraulic 'motor' and the compressor shaft..Originally Posted by smufguy
All in all, I think this is actually a very good idea. I think that doing this electrically would be difficult for a number of reasons, and I think the parasitic losses of the hydraulic sytem when not in boost could be minimized quite effectively. As gas prices continue to go up, people are going to seek ways of extracting more and more power out of smaller engines, without sacrificing low rpm power, you know how oems are with their undersized turbos..
princess auto sells all the shit here to mok somthing up hehe, gearing wiseOriginally Posted by Accordtheory
i was actually thinking using chains to step up the rpm
