Results 1 to 18 of 18
Thread: Wheel sizes ---> speedometer adjustments
    Whistler225's Avatar
    Mar 2006
    86/Honda/Accord LX
    Concord, NH
    ok, does anyone know how much various non-stock wheel/tire sizes effect speedometer readings? On the same topic, it may sound stupid to some, but does anyone know how to adjust the speedo cable to compensate?
    Idaho
    Re: Wheel sizes ---> speedometer adjustments
    You can't adjust the speedo. My 17's made it off by 5%. Can't remember if faster or slower. BTW, paul has a site i believe.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    A bit off topic...but good to see a fellow NH'er on the board...
    Anyway...how big of a difference is there in tire size? I go from my 17'swith low profile tires to my 15" rims with snow tires with little dif.
    LX User paso100's Avatar
    Mar 2005
    1988 Accord LX-i sedan
    Central California Coast
    This will give you the percentage change of your speedo.
    http://www.miata.net/garage/tirecalc.html
    Quote Originally Posted by paso100
    my spedo going 1.1% and i cant feel a diference ppl should stay at a 0-5% level... ig you are going to get 17 inch rims you will have to get 205-40-17 tires
    Remember it not so much the rim size but the over all tire size that makes your speedo off.
    Quote Originally Posted by Whistler225
    when I went from a 185/70/13 to a 195/65/14 I had no problems with my speedo reading
    1991 Civic STD
    Arbutus, MD, Baby
    You should be able to get the speedo recalibrated professionally...
    Not something you can do yourself, though.
    Daily Drivers Done Right
    Mar 2006
    86/Honda/Accord LX
    Concord, NH
    Cubert: yeah, not too many 3G's on the road around here due to the salty roads...mine needs a little body work as it is. But, for 100 bucks, and it gets me back and forth to work and runs pretty darn well, I can't complain.
    I think I'm going to try and find some Acura rims at the JY....or anything off an Acura or Honda really...I don't want to buy 400 dollar rims for a 100 dollar car, but I would like to replace the original hubs that came on it...
    I guess if I only go to 14 or 15, it won't make enough difference for me, especially since I'm one of the only people in this state who drives at a reasonable speed ;-) I only go about 5-10 over, while everyone else does at least 15 over.....lol.
    Cubert: what part of NH are you from? I'm in Concord....do you know any decent JY's around here where I can find 3G's?
    Feb 2003
    NH
    im from nashua...and the jy i go to is in Candia...and only has one or two sadly
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    True, I agree with that.
    DX User accordrollingon18z's Avatar
    1989 honda accord lx
    north carolina
    i have 18s with 205/35/18 tire and it didnt hurt the mileage at all
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    your milage? your speedo accuracy you mean?
    Mar 2005
    Saskatoon
    ohhh I think I get it, saying youd get less milage because of the 18's turning slower.... hmm, good one
    that'd be true if the wheels large size didnt put such a load on the small engine the 3gee has. larger wheels = less engine rotation. but the how heavy they are makes a difference also. if you think about it, in the long run you'll be putting less miles on the speedo's reading with larger wheels. dont know if anyone noticed that.
    Mar 2006
    86/Honda/Accord LX
    Concord, NH
    yup. I did. Larger wheels= fewer wheel rotations at a given speed versus smaller wheels, therefore fewer engine/transmission rotations, so as long as your wheels aren't alot heavier than factory, I would think you'd get better gas mileage. If they're the same weight or lighter, you should get much better mileage.....
    Mar 2007
    Sylmar calif. part of Los Angeles
    Quote Originally Posted by HondaBoy View Post
    The Effect of Wheel Inertia Weight
    From HP book - Honda/ Acura Performance
    On a 93 Civic Si that came with 14" wheels they put on 17" wheels with tires that had the same outside diameter. The car accelerated noticably slower. 6 hp less on a chassis dyno. The 17" wheels weighed 8 lb more and the reason the car accelerated slower is because they moved the weight farther toward the edge of the outside diameter.
    when my speedo was inaccurate i puttled it apart and moved the needle a bit lol. but now with the digi dash it have to leave it wrong
  1. Wheel sizes 83 sedan
    By accord83 in forum 2geez Accords
    Last Post: 04-04-2009, 12:50 PM
  2. Wheel Sizes......
    By iloveJDMblackrims69 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-07-2003, 02:09 PM
  3. wheel sizes
    By Justin86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-07-2003, 01:09 PM
  4. Steering wheel adjustments
    By amalgumjoe in forum Classic Honda Community Chat
    Last Post: 09-01-2002, 09:33 PM
  5. New to wheel sizes!!
    By MC Pee Pants in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-14-2002, 06:18 PM
