Results 1 to 19 of 19
Thread: Can we remove parts?
    87accordlxph's Avatar
    Carbed 1987 Honda Accord LX & Black 4th gen Accord (91)
    Petrolia, Ontario Canada
    Hey guys I was just wondering if we can
    remove any engine parts to make life
    much more simpler like the PCV Valve?
    Any ideas?
    A20A1, I think on your website you mentioned some
    of these parts removed?
    -Mike
    Mike's Clean Cnd A20A2 5 spd Champaigne Beige Sedan Accord, Eh!
    B-Day: 07/87 in Alliston, ON Canada
    The best mods are mods that can be modded over and over again.
    Aug 2001
    1988 Accord DX 5spd
    Dayton, OH
    I'm pretty sure that you need the PCV valve or else the gases will build up inside your engine. I think that they could build up enough pressure to cause serious damage to the eingine.
    accord HB ( metallic green)
    B.C Chilliwack
    Well if its carbed, get rid off the EGR valve, and then you can follow the hoses and get rid of anything related to it. Off course if you need emmisions this might not be a good idea.
    I did it to my car, it worked fine didn't change anything.
    Oct 2001
    87 Accord EX , 5spd , Manual
    in my opinion everything removed has a side effect ! honda didn't just put anything there !
    MIKE
    B.C Chilliwack
    Your RIGHT its there for emmisions control !
    LXi User Jerren's Avatar
    Jul 2001
    1991 H23 powered Accord EX Wagon , Turbo 91 Honda CRX, and 96 Blazer LT
    St. Louis
    if you want to lose weight, take out your passenger seat. or do you need that? how about your spare tire (full size)and your rear seat.
    GDGuy11B's Avatar
    Jul 2001
    1989 Accord LX-i, 00 Civic EX
    Back from Baghdad (Tallahassee)
    why would you choose to remove the PCV valve? it doesn't weigh anything, and it's out of sight, if you want to free up some space in the engine bay lose your power steering and a/c.
    Micah
    89 Silverstone Metallic LXi, custom Air Intake, DC Sports 4-2-1 header, A'PEXi N1 exhaust with 2.25" pipe, ACT clutch, Xenon body kit
    3geez member since July 11, 2001
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    I say rip yer backseat out, that alone should lose ya atleast 50 lbs., and the spare tire, and then all the material in between the seats and the floor.
    R.I.P. Died on 7/2/03......
    88 Lxi/ 5spd
    Tennessee
    pcv valve prevents blowby gas from worn piston rings from building up in the crank...with no pcv valve you will start to rupture gaskets and get oil leaks like crazy. not a very smart move. i don't really see it being an emissions device but rather a maintenance item that saves you from doing work on your car. on the other hand the egr valve will gain you some power by disabling it cause it is an emissions device. And for all the the people serious about weight here is the break down i've what i dropped.
    1.)cat and exhaust tubing....25lbs
    2.)aftermarket rims.....15lbs
    3.)ac and ps systems.....25lbs
    4.)iron front reinforcement bumper....20lbs
    5.)rear reinforcement bumper....20lbs
    6.)lighter battery......10lbs
    7.)backseat.....30lbs
    8.)everything in the back half of the car....30lbs
    9.)spare tire......20lbs
    10.)sway bars....10lbs (this is a track car) not recommended for street.
    posted 9.9 ets at 72mph in 1/8 track....a20a3....stock bottomend and no head work......jteuton
    In the end...it doesn't even matter.
    88 Lxi, 5spd swap w/ Aasco 8lb flywheel/Cai,AccelCoil,NologyWires,SilverstoneSparks/DC421,ColtCam,Remachined Head&Tb...NitrousWorks 40shot
    10/Honda/Ridgeline
    NJ
    if u really wanna take something out, take the power steering out, it wont increase ur hp or stuff like that, but it would just give u more space, but would suck with our cars to turn on standstill. u can move your battery to the back if u want to. there is'nt anything u can just take out. why do u wanna pull something out anyways?
    AT MOST the backseat weights 15 lbs, it's all sponge except on the rear a sheet of 1mm steel that looks like swiss cheese.
    removing the PCV is not recommended but possible... it'll create a lot of air in the oil passages though as the built up pressure tries to escape out the valve cover. EGR can be removed as well as the air suction device but you will need to get a set of headers or have some plugs welded in the holes of the exhaust manifold. The vacuum accesories can all be removed if you get an aftermarket carb as well as all the electronic gadjets strapped to the fenders. I gotta get you guys a pic under my hood, nice and spacious
    Eric
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    I never removed my PCV... I just added the new crankcase filter, so i could dump the old foam one attatched to the stock air box.
    1987 accord sedan
    Halifax
    actually removing the PS system wiil give you some HP since it's run off the crank when you remove it it will no longer have to run the belt/pulleys and then free up maybe like 1-2hp....
    like adding underdrive pulleys...etc
    ever notice that Stock cars mostly don't have Power steering on them...
    nothing
    10/Honda/Ridgeline
    NJ
    yeah exactly, removing stuff does not increase your hp gain in a major way, but adding something to your engine, would def increase your HP as u know
    Justanothermike's Avatar
    88 LX-i coupe 91 LX coupe
    CA, San Francisco
    the 88 coupe runs 10.0 1/8miles, only difference is all that stuff mentioned is still in the car(except for the spare tire).
    other things u can do to increase HP are:
    1)Remove cat
    2)remove all accessory belts(ie. ps, ac)
    3)remove air filter
    4)100 octane unleaded fuel
    5) advance timming ignition
    6)smaller diameter front wheels/tires
    7)lighter front wheels/tires
    8) bump up fuel pressure
    9)remove emmissions
    Off course these are TRACK only modifications
    WOW
    Thanks for all your replies guys!!!!!!!
    I didn't know this tread was soooooo popular!
    Regards,
    -Mike
    10/Honda/Ridgeline
    NJ
    and oh yeah, the name MIKE is way too popular too.
    1987 accord lx-i
    utah
    air box is only like 5lb if that so probably the only reason to remove it is to free up space
    hmm and you thought the reverse polarity of the sun made you loose to a 3rd gen accord
    1987 accord lx-i
    utah
    my hole stock air box is removed along with pvc valve i have one of those little filters on my valve cover now now
  1. Random 3gee parts, civic parts, and other hondas
    By labeledsk8r in forum For Sale
    Last Post: 09-03-2009, 10:09 AM
  2. how-to: remove rust from parts
    By Vanilla Sky in forum 3geez Accords
    Last Post: 12-03-2004, 02:14 AM
  3. Replies: 0
    Last Post: 02-12-2004, 09:10 AM
  4. FS: Wheels, subs, integra parts, accord parts
    By kicker1_solo in forum Trading Post
    Last Post: 09-23-2003, 05:07 AM
  5. [Engine & Transmission] Remove A/C
    By YK86 in forum How To
    Last Post: 05-29-2002, 01:35 AM
