I had this idea hit me a couple days ago. I have this Accord, its high mileage, and carbureted, and soooo underpowered. I love the car, its in great shape, rides great, and it's not too bad lookin of a car, but I just cant stand having 98 HP (probably somewhere around 75 or so having 182K on it) I also have a 96 Acura Integra GSR. While I had the hood up checking the oil, I noticed how similar the two engines are between the cars. Now I wonder, is there a DOHC 1.8L VTEC engine that I can drop in the 89LX that will bolt up fairly close, with minor modifications? Driveaxles are not a problem from what I can tell, I think I could easily have a set made from mine and some wrecking yard ones to create the proper length and adapt the transmission end to whatever transmission I'd wind up with.
If I were to get a complete engine, trans, ECM, and wire harness, would it be about as simple as getting it mounted up, hooking up the drive axles, mounting the ECM, connecting the shifter with some minor mods, get the exhaust downpipe replaced to fit the new header and location, and then some wiring and hoses retrofitted?
What 94 or newer VTEC engine will come closest to fitting in this car? I'd rather have a 96 or newer for the OBDII connection, but it's not a must. I'm really considering doing this swap just because I like the car, I have alot of time invested in refurbishing it and making it look like new again, and would like to give it some more power while increasing its driveablility and reliability factor. And on top of all that, what a friggin sleeper eh???
