Ok, since I have learned, with the help of all you, that the B18 Intake Manifold will work with our A20 head with minimum customization, But heres the thought, could, and if so, would a COLD AIR INTAKE be hard to make for this manifold?
I was thinking that I could do some welding and get like 4 pipes to come off of that pointing towards the passenger side, one stacked above the other, and then get all 4 to some how become 1 Pipe, but I was also thinking that I could make a RAM AIR intake and use something like the stock air filter and some real planing and thinking to get this to work right, If I could design a caseing around the 4 intake ports that would have my stock air cleaner on it, and have it to where it is only closed when the hood is closed, like a hot rod, I hope your imagining this right, but I think if you guys belive it is posible, that would be a MAJOR Upgrade for performance. Please shed some light on your thoughts, I would realy apretiate it.
