Results 1 to 25 of 28
Thread: Lowering Accord = Death of 2 Transmissions... *Pics to prove*
    LX User JFreddy's Avatar
    Mar 2004
    1989 Honda Accord ex-i
    Airdrie AB, Canada (By Calgary)
    Thumbs down Lowering Accord = Death of 2 Transmissions... *Pics to prove*
    Alright, I finally have pictures of my second transmission to get fubarred from cruisin in the accord after its been lowered. Some of you hopefully have all seen the previous thread I made containing two different theories about why this is happening so then you'll know whats goin on, basically my axles are hitting the diff pin and taking chunks outta it, I'll let the pics speak for themselves (oh ya and then it starts to rip through the casing and thats where it leaks out tranny oil. lol. Now if anyone can help in figuring out why this happens to only my accord and how i can prevent this next tranny from doin it... it would be greatly appreciated (yes the car is raised again its only lowered one inch right now cas im too scared to drive wit it any lower.)
    It's not what you drive, It's that you drive what you got! I LOVE MY 3Gee!
    '85 Honda Accord HB
    OrLaNdO
    Re: Lowering Accord = Death of 2 Transmissions... *Pics to prove*
    pic is broken...
    Mar 2004
    how do i fix it? im tryin to do that right now?
    Mar 2004
    Mar 2004
    Mar 2004
    Thats all I got for now, and the first tranny was worse there was about an inch diameter hole where this one started to maek a hole... so yeah.... any ideas on how to make this stop?
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Whoa thats mangled bad.... I remember someone saying something about your engine mounts... did you check em?
    HOLY DIFF PIN. Are your diff bearings shot as well? Or is it just the diff pin?
    i don't know, but i know for the fact that many people on this board have their cars lowered and never had this kind of problem. I had my car lowered 1.7" all the way around and my tranny is good.
    You should check the engine mounts and make sure they are OK.
    DX User Gerroni's Avatar
    Apr 2006
    1988 LXi
    Puyallup, WA
    ouch.... check ur mounts i heard the same things. factory mounts go bad after 100k or something like that.
    Vanilla Sky's Avatar
    1999 Penalty Box
    i still stand by what i've said before, and that it's the motor mounts.
    Mar 2004
    Ok, so what do u mean by check them...? how do I know if they are really bad as opposed to just old? and I dont know about the bearings but ya this has happened to two transmissions... this one is actually the better one... well i took it out before more damage was done... and I'm still taking it apart so later on I might have more pics of all the parts taken out.
    P.S. The techs at work keep saying its cas u lowered ur damn honda... blah blah blah... but the thing that I cant grasp is y its only happened to mine.... argh... lol. Once I figure out how to check my mounts I'll do it, or should I just do the 3M window welder trick to stiffen them up?
    1999 Penalty Box
    window weld is ok. i prefer to simply install new OEM replacement mounts. you don't have enough power to warrant harder mounts. all you'll get is a lot of annoying-assed vibrations that you'll kill yourself over.
    grab a prybar and see if you can move your engine around. if you can, you have at least one bad mount. get up under the car and inspect the mounts as best as you can visually. feel them a bit. you certainly can feel cracks in them, and especially the oil leaking from the front mount.
    i'm leaning toward the rear mount or the side mount. the front mount, the trans mount, and the torque strut have less effect on the trans position than the rear and side mounts.
    SEi User 3gn86lxi's Avatar
    Jul 2004
    wa
    Geeeeeezzzzzz.........
    I wouldn't do anything to "stiffen" the mounts, just REPLACE them!!! Next tranny you have put in, have them replace all the motor mounts too.
    My car is lowered 3 inches in the front, 2.25 in the back.............NEVER have issues with the transmission.
    You definately have other issues, Honda techs don't know what they are talking about.
    ~Ryan~
    Mar 2004
    Alright so I'll get soem new motor mounts, and then do you guys think i'll be safe to be a low rider again?
    And when do you have enough power that you should look into stiffer mounts?
    1999 Penalty Box
    the guys that are shredding stock mounts are about the only ones i'd see with a need for stiffened mounts. these aren't race cars for the most part. when you get to that point, consider new solid mounts. the car would be unstreetable, but you'd get more power to the ground the instant it was applied, instead of when the mounts bottom out.
    If your mounts are OK....
    I'd look at the lengeth of the axle/axles. Seems at compression there smacking into the pin in the dif and busting the case.
    Not sure what the lenghts are susposed to be but look on NAPA online they list the legnths.
    10/Honda/Ridgeline
    NJ
    my car is lowered 2"s and i my lowest ground clearance is 3"s off the ground. My axles and boots are perfectly fine and my tranny is in perfect shape. I don tknow how/why you went thru trannies like you mentioned. My motor mounts are stock as hell. i dont know how old ur shocks are and how they are articulating. If moving parts are hitting each other, there is something really wrong with the suspension geometry on ur car.
    Mar 2004
    lol. agh this is sucks, k my motor mounts i checked them out, they are alright, old i suppose so I ordered new ones from honda. My tech at work doesnt really buy the motor mount thing though... My axles are the same length as stock, I've replaced both of them with NAPA CVX axles, uhm I got an idea... still a shot in the dark but with my car lowered 3.25" if my front struts were blown... and my suspension was mostly coil would that effect it ?
    10/Honda/Ridgeline
    NJ
    lol yeah that would affect it. with 3.25" lowering, u can lick the road clean with your rear bumper. raise the cr up so u can get the axles articulate better.
    Mar 2004
    But ... but... i love the look of our cars just dumped... lol it is up now, its only down 1.5" on each, and k i feel a lil stupid asking but, by articulate do u mean just line up better and work with less stress? and if so ya thats what ive done for now, but i miss the super low look
    DX User 89AccordLX2dr's Avatar
    Oct 2003
    89 Accord LX 2dr, 91 Park Ave Ultra
    Ontario, Canada
    Doesn't matter how low or high your cars riding height is, aslong as it's within the original suspension travel limits. Something is moving side to side, be it the engine, or a wheel assembly due to broken bushing or mount... or you have incorrect length C/V's
    86-89 : Right(man or auto) 19.7-19.9 in. Left(manual) 31.3-31.5 in. (auto) 31.6-31.8 in.
    89 Accord LX 2dr Coupe - 240k
    Oct 2003
    Ontario, Canada
    Ohhhhh you replaced your Half Shafts with something made for a different car maybe... The length of the shaft may not be the problem, but the input shaft may be too long/deep into the tranny.
    10/Honda/Ridgeline
    NJ
    articulate means to be able to move up and down freely without any restriction. its a bio-engineering term. i guess the webster has it otherwise
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    my thoughts on this as well. Have you been using the same set of axles on both trannies?
    Link to my 3geez garage
  1. Replies: 2
    Last Post: 10-27-2010, 04:30 PM
  2. Replies: 50
    Last Post: 04-09-2006, 09:06 PM
  3. Turboaccord pics... 56K DEATH
    By AccordEpicenter in forum Classic Honda Pics & Videos
    Last Post: 12-05-2005, 04:01 PM
  4. Here are my Civic Pics (56k Death)
    By L337Ride in forum Classic Honda Pics & Videos
    Last Post: 11-23-2005, 01:00 PM
  5. Member request, before & after 1.5" lowering pics
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-06-2003, 09:59 AM
