Results 1 to 10 of 10
Thread: Smoke from the steering column
    Smoke from the steering column UPDATE
    Well shit just what i needed moving into a new house and all. I came last week from work and when i pulled the key out of the igntion I swear i saw smoke. I ran into the house like a nut found some pliers and pulled the battery termial off. No damage but now I can't find what smoked.
    I have unhooked the radio, checked fuses ran the car several times and I can't get anything to happen. I got the covers off the dash and the steering column. I'm taking it home tonight and maybe the headlights had something to do with it. I got the fire extingusher riding shotgun and the positive terminal loose
    Of course on a unrelated note I got no idle since the battery terminals been off. That always fun to deal with.
    Re: Smoke from the steering column
    Heh well not my best idea. 10 min ride i got light smoke seems to be the wires going to the left side ( my left) steering column used for the head light switch. Seems upper red wire and large white get hot and associated board there sodered too. I checked this all while going about a 100 down the highway.
    Anyway i killed the lights once i got off I -40 and ran the hazards the rest of the way home and it cooled off so its headlight related
    LXi User TheWatcher's Avatar
    Feb 2005
    1989 Honda Accord LX
    Quote Originally Posted by Oldblueaccord
    I thought that only happened to Fords. I once saw a Ford steering column go up in smoke.
    That's why I always carry a socket set in the trunk, so I can disconnect the battery, if necessary.
    Peace.
    It ended up being the combination switch was bad. Its the stuff the lights stick and the wiper stick are attached to. I'm back and running.
    Vanilla Sky's Avatar
    1999 Penalty Box
    yup, that's the combo switch, like you discovered. i would assume it was the grease that got a bit too hard and caused too much resistance, or a loose solder joint. i've rebuilt a couple, and they're all fixable problems.
    LX User Mars's Avatar
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    Quote Originally Posted by TheWatcher
    Peace.
    Hah yeah, i had that happen to an old maverick i once owned.
    Quote Originally Posted by Mars
    Yep parents old maverick did too. 3 days new. Never did work right after that. We nearly frozze to death as little kids in that car.
    Feb 2005
    1989 LXi Coupe
    Dallas Tx
    they are nearly indestructable tho
    DX User GOTWILDRICE's Avatar
    Feb 2005
    Had the same smok'in steering colum problem - and yes is was the combination switch - i figured it was coz i had the head light conversion units w/ blue simulated HID bulbs- this puts extra power thru the switch and caused the burning - a good idea is to place a relay on the regualr beam head lights since only the high beams are on a relay. Since ssomeone stole the connversion headlights out of my car I've not had any further smok'in issues
    Aug 2008
    1987 honda accord lxi hatch
    lincoln
    Re: Smoke from the steering column UPDATE
    i am currently having the exact same problem. i already replaced my combination switch but the thick white wire is still getting hot. this only happens when i turn the headlights on. could it be a short somewhere in my wiring or just another bad combination switch. i have an 86 hatch lxi.
  1. New steering column, no start
    By Lead Foot in forum 3geez Accords
    Last Post: 10-05-2011, 05:08 PM
  2. Steering column rattle
    By Xulfiqar in forum 3geez Accords
    Last Post: 02-09-2007, 05:00 PM
  3. how do i drop the steering column?
    Last Post: 09-25-2005, 06:45 PM
  4. Smoking Steering Column
    By 3rdCoast in forum Carburetor Tech
    Last Post: 08-08-2005, 09:08 PM
  5. How to lower steering column?
    By toastyghost in forum Interior & Exterior Care
    Last Post: 06-21-2002, 12:22 AM
