Results 1 to 25 of 27
Thread: Where to actually FIND turbo manifold?
    LX User maxsideburn's Avatar
    1990 Honda CB7 Coupe, 1992 Eagle Talon TSi AWD
    Lafayette, Louisiana "The Hub City"
    I've seen lots of things on the boards about turbo-ing your car, and they've been very informative, but where do you actually find a turbo exhaust manifold for an A20A3? I can't seem to find one anywhere I've looked.
    I read somewhere that marijuana effects the memory. Can't remember where I read that. -- maxsideburn
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: Where to actually FIND turbo manifold?
    You build one or have one made.
    Alex
    yeah no one will make a turbo for our cars since i think not all of them are fuel injection. on a parts website and they only have B and D series set ups. like 86AccordLxi said everything has to be built. check out Victors setup.
    wow, well in that case I think I will just stick to naturally aspirated. If I ever drop in a new slightly built motor I might even hook up some nitrous to it, that way I can have the power when I go to the dragstrip Just run a small shot.
    I was considering turbo, but if I have to go through the trouble of getting a turbo manifold for it I think I'll just wait.
    Quick question though, what does it usually cost to get one made?
    SEi User
    south dakota
    why don't you try to make a tri-y top mount using a simple extension from the factory 88-89 manifold.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    some company in canada makes a turbo manifold for us, the links somewhere in here just look it up.....
    -Gio
    My E85 Turbo Build
    5280FEST
    snoopyloopy's Avatar
    Killa Cali
    Quote Originally Posted by gfrg88
    yeah, those manifolds run like $750 CA. so that's probably about $650 US. you can get one custom-made for cheaper. much cheaper if you can do all the welding yourself. but how well it'll perform depends on your design.
    LX User 87preludeA20A3's Avatar
    1987 Honda Prelude
    Southern Cali
    hey there i have a turbo manifold and a freshly rebuilt turbo i will sell bith for $650 plush shipping... check out my turbo here....
    https://www.3geez.com/forum/showthread.php?t=51853
    And the manifold is the one Elijah had....The first one under tube mani's... I want something i saw today and want money.....lol
    https://www.3geez.com/forum/showthread.php?t=37169
    LX User fraza's Avatar
    87 Accord Si
    Australia, melbourne
    hey man make one yourself, its realy not that hard, get a stock manifold and grind off the pipes so its just the plate, then have someone mill the plate so its flat, then get 3 1.5 steel t pieces and a 90 deg bend and weld it up then put a turbo flange on itif your not confident with a welder just tac weld it then have a pro welder do the rest for ya be alot cheaper than getting someone make one
    dont worry mate, that'll buff right out
    Killa Cali
    Quote Originally Posted by fraza
    in that case, just talk to SQ is the SQUAD. he's doing the exact same thing, except he found someone who sells just the exhaust manifold flange. it'll save you a bit of trouble from having to cut and grind.
    hmm, that just sounds like tons of trouble. I think if I go turbo I'll do it on my little 91 Civic, I can get the manifold for $150, lol. The more I think about it I think I'll just stay NA with the Accord since turbo parts are hard to find, but thanks anyway guys I was just curious.
    LX User Sporno's Avatar
    1987 Honda Accord LXI
    Richmond ,VA
    i think full race offers one
    2006 NASA/VCU regional Semi-finalist
    2006 FIRST Robot Rumble Quarter-finalist
    2006 FIRST Robot Rumble - Most Promosing Rookie Drive team.
    2006 Championship Curie division
    2007 NASA/VCU- Regional Winner
    2007 Championship-Galileo
    74+ matches on the feild
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Quote Originally Posted by Sporno
    rofl.
    DX User JakeEXLS's Avatar
    Sorry ta bring this back up after almost a month, but just a wee question...
    Vs.
    http://www.beesandgoats.com/boostfaq/g2icturbo.html
    "You cannot modify and use the stock exhaust manifold or an aftermarket header. It will not work, do not try it."
    So is it ok to modify the stock manifold? Or not?
    Ok, and one other dumbass question while im here - a18a a20a exhaust manifolds the same? yes?
    Jun 2001
    Boston MA
    alot o d sereis manifolds are capable of being modded as a turbo manifold. i just saw a thread on homemadeturbo where someone modded a 2 pc header like our dc/pacesetter header unto a top mount turbo manifold
    S.Q.U.A.D. Engineering
    www.squadengineering.com
    Nov 2002
    Ridin Dirty in New York
    thats gonna work until the primary tubes melt unless its full stainless. It could be done on a stock cast iron exhaust manifold, kind of like an up pipe configuration
    LX User Swap_File's Avatar
    Manual 89 Se-i Accord
    Minnesota
    This is what I am going to try to do:
    http://www.honda-tech.com/zerothread?id=1564066&page=1
    Last I checked, the front crossmember gets in the way on our Accords, but that was when my engine mounts were broken. Maybe now the pipes will clear. Otherwise I will have to hack up the crossmember and weld it a bit.
    I am just finishing up my B series radiator swap, along with my manual swap. I will post a how to in a week or so about both projects. I took lots of pictures. Next up will be the OBD-1, and then I will work on this turbo manifold.
    Nov 2002
    that would work although i have no idea how well. I bet it would be better than a log but ive only seen a handful of guys run them like this so im really not sure. I had to cut up my crossmember for my turbo set up, its tough to make things fit right in there but im sure its a possibility
    A Mile High.
    ive been talking to some people from f22parts.com about them making a manifold for us, so far whar ive got is that he doesnt need a group buy, they can make them as we order them. if three or more persons order at the same time theres a $50 discount on each one. ill keep you guys posted on this
    -Gio
    My E85 Turbo Build
    5280FEST
    bobafett's Avatar
    Longview, WA
    yeah if we have them use an a20 flange, and we have them put the turbo outlet lower (so the turbo doesnt sit so far forward in the engine bay) we could put the WG in the middle (better) and with a civic radiator on the passenger side, I think this could work nicely!
    good find with that f22parts.com people!
    EDIT: omg that manifold looks so much like an A20 manifold it makes me excited to look at it... heheha
    A Mile High.
    yeah ive been talking to the owner and i told him about this site. he said they make all kinds of custom parts and they could easily make other parts for us too. he said he doesnt need a flange or anything that hes going to try and find as much info as he can. hes sounds like a good guy so hopefully i can get one made from him and you guys are going to be able to get them too.
    -Gio
    My E85 Turbo Build
    5280FEST
    bobafett's Avatar
    Longview, WA
    i would be MORE interesting in paying a bit more for an ELR manifold personally, but if we can start off with some logs that fit, that would be more than acceptable.
    the HT log vs elr dyno video (granted on a high hp car) proves to me that elr is worth the money/hassle... ill see if i can dig up the video
    EDIT: i found the video, 250whp with log manifold, 312whp with equal length manifold. WELL worth the $300-$400 price difference.
    Jun 2001
    Boston MA
    bobafett, with my xspower t3/t4 i found it esiest to mount the flange directly undetr the 2 and 3 runner and mount the bov flanfer off the top of #2. i am using a civic half rad all the way to the passenger side and its still a tight ass fit
    A Mile High.
    Quote Originally Posted by SQ is the SQUAD
    i dont think you shouldve gotten a xspower turbo
    -Gio
    My E85 Turbo Build
    5280FEST
  1. ordered a new compressor, can't find manifold seal!
    By POS carb in forum 3geez Accords
    Last Post: 07-19-2012, 07:29 PM
  2. Hoping to find a turbo manifold
    By 1990DSM in forum Forced Induction
    Last Post: 01-29-2008, 08:37 PM
  3. Replies: 8
    Last Post: 02-11-2004, 05:30 PM
