Get in here and vote! Since Wickedaccord and Carotman were tied at 30 votes apiece at the time the main poll closed, we will do a runoff poll to determine the winner. This will only be open for 24 more hours. As always, no posting is allowed in the voting thread.
Wickedaccord:
-benson's 2.0 resleeved GSR block, fully balanced and blue printed by bensons machine, cp pistons, manley rods, 9:1 compressiona fantastic 409whp at a mere 12psi, at 17psi, it made giant mid range power. top end dropped off because the injector size are too small. we should've gotten 750cc injectors, but no one expected this amount of power at just 12psi. 486whp could've easily been achieved with 750cc injectors. possibly just a little over 500whp. another problem was due to clutch slippage. again, no one expected these numbers. so a stage3 exedy clutch was opted for. now we have to get an exedy twin plate with flywheel.
-PnP b16 head/multi angle valve job
-ctr cams
-hondata i/m gasket
-str 68mm t/b
-skunk springs/retainers
-hondata s200b p30 ecu
-LSD cable tranny
-full race stage3 GT turbo kit (GT35R)
-custom 3 inch exhaust
-itr cams
-itr manifold
VIDS:
http://keruh.com/3gz/wickedaccord_dyno.mov
http://keruh.com/3gz/wickedaccord_civic.mov
http://keruh.com/3gz/wickedaccord_civic2.mov
http://keruh.com/3gz/wickedaccord_cruisin.mov
ALSO THIS IS A DAILY DRIVER
Carotman
1989 Canadian LX:
Engine:
90-93 Acura Integra Cold Air Intake
MSD SCI Ignition
MSD Blaster 3 Coil
Complete 89 Accord PGM-Fi engine conversion
89 Accord SE-i OEM Dual Tip Muffler
High Flow catalytic converter
Pacesetter Adjustable Throw Shifter
Completely rebuilt JDM B20A Engine swap
Noredline lightened 88-89 Prelude Flywheel
Custom CNC Machined adjustable camgears
Integra Type-R Pistons (.25 Oversize)
11:1 Comp Ratio
Polished Crankshaft
Polished connecting rods
Ported and polished head
Colt performance Camshafts
Eurethane Engine Mounts
ACCELL Performance Spark Plug Wires
DC Sports 4-2-1 Ceramic Header
PH3 ECU
Handling:
Enkei RT-01 16X7 Wheels (16 lbs each)
Toyo Proxess 205/45 ZR 16
Neuspeed Sport Springs
Koni Red Struts
4 wheel disc brakes conversion
Front brakes: Axis Metal Master pads with PowerStop X-drilled rotors
Rear brakes: PBR Deluxe pads with Brembo x-drilled rotors
89 Accord SE-i front and rear sway bars
Ingalls front Camber Kit
DC Sports front strut bar
Esthetics:
90-93 Honda Accord OEM Spoiler with LED
Cleared bumper lights
JDM OEM front bumper lip
JDM OEM heater controls
JDM OEM Power folding mirror conversion
Momo Racing Line steering Wheel
Painted valve cover
Painted Calipers
Tinted Windows
Power doorlock conversion
Power windows conversion
Full length armrest
89 Accord SE-i cupholder
90-93 Acura Integra Headrests
Rear DOHC Emblem
Lightning:
Eurolite H4 diamondback headlight conversion
80W/100W Ultrawhite Bulbs
Ultrawhite parking lights
JDM OEM corner lamps
Soon to come....
JDM Map Light
JDM Auto Climate Control
