Results 1 to 6 of 6
Thread: Accord of the Month Nominations - June 06
    87accordlxi's Avatar
    Oct 2000
    Its time to nominate your favorite ride for AOM: June 06
    Check out the Rules & Regulations
    All winners in the past year are ineligible for nomination:
    June 05 - ICEMAN707
    July 05 - BustedBlue
    August 05 - Mr Eff
    September 05 - thegreatdane
    October 05 - 88' Accord Ltd
    November 05 - 3GN86LXI
    December 05 - Adams86LXI
    January 06 - AccordEpicenter
    February 06 - Jigga225
    March 06 - Hondaman87
    April '06 - Legend Master
    May 06 - carotman
    Members must have 50 posts in order to nominate someone
    Duplicate nominations will be deleted
    Posts made that are not nominations will be deleted
    Invalid nominations will be deleted
    There is no need to second a nomination! If a nomination is valid, it will proceed to the voting stage automatically.
    - Joe
    SEi User B16KILLA's Avatar
    SO,CAL
    Talking Re: Accord of the Month Nominations - June 06
    I nominate AcidX (aka Cory)... Mods Cosist of:
    Tokico HP Struts
    Dropzone Springs 2.5'' Drop
    16'' Enkei OR-52's
    Dunlop SP Sport FM9001'S (205/45/16)
    Pilot Fog Lights
    Integra Lip
    Armrest
    Cupholders
    Civic Box w/Custom Lid
    Custom Short Ram
    Crane Cams 11mm Spark Plug Wires
    Axle-back 2.5'' Exhuast
    Magnaflow Muffler
    Also a immaculate interior
    Nov 2002
    Ridin Dirty in New York
    i nominate WickedAccord because he is my hero
    a fantastic 409whp at a mere 12psi, at 17psi, it made giant mid range power. top end dropped off because the injector size are too small. we should've gotten 750cc injectors, but no one expected this amount of power at just 12psi. 486whp could've easily been achieved with 750cc injectors. possibly just a little over 500whp. another problem was due to clutch slippage. again, no one expected these numbers. so a stage3 exedy clutch was opted for. now we have to get an exedy twin plate with flywheel.
    -benson's 2.0 resleeved GSR block, fully balanced and blue printed by bensons machine, cp pistons, manley rods, 9:1 compression
    -PnP b16 head/multi angle valve job
    -ctr cams
    -hondata i/m gasket
    -str 68mm t/b
    -skunk springs/retainers
    -hondata s200b p30 ecu
    -LSD cable tranny
    -full race stage3 GT turbo kit (GT35R)
    -custom 3 inch exhaust
    -itr cams
    -itr manifold
    VIDS:
    http://keruh.com/3gz/wickedaccord_dyno.mov
    http://keruh.com/3gz/wickedaccord_civic.mov
    http://keruh.com/3gz/wickedaccord_civic2.mov
    http://keruh.com/3gz/wickedaccord_cruisin.mov
    ALSO THIS IS A DAILY DRIVER
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    I want to nominate:
    88LXi68
    Exterior
    CF Hood
    90-93 Integra Spoiler
    Body matched moldings
    JDM corners
    Se-i alloys (currently)
    Interior
    90-93 Integra Headrets
    84-87 Prelude shift knob and boot
    autometer volt and EGT gauge
    SE-i center console and SE-I cupholders
    Suspension and Brakes
    Ground Control Coil Overs
    Koni Special Struts (Reds) all around
    84-87 Front Upper Prelude Arms
    Ingalls Rear Camber Kits
    Addco Front and Rear Sway Bars
    DC Sport upper strut bar
    88TurboAccord rear strut bar
    Se-I rear disc conversion
    Brembo Cross Drilled and Slotted Front & Rear Rotors
    Techna Fit braided lines
    Axxis Metal Master Pads
    Engine
    LS/VTEC Swap
    B18A1 Block
    Arias 11:1 Pistons
    bored .10over
    Eagle Rods
    new bearings
    honed
    balanced
    clearances checked
    Place Racing Mounts
    B16A2 Head
    CTR Cams
    Fererra oversized valves
    ITR Valve Springs and Retainers
    Port and Polished
    3angle valve job
    ITR Intake Manifold w/ ITR Throttle Body
    JDM 4-1 Itr Exhaust Manifold w/ 2.5" outlet
    AEM Fuel Rail
    B&M Fuel Pressure Regulator
    Short Ram Intake
    2.25 Exhaust no cat upgrading to 2.5
    Drivetrain
    LS Integra S1 tranny
    ACT Extreme Pressure Plate
    ACT Steet Disc
    SCT Streetlite flywheel
    Place Racing Axles
    Pacesetter 84-87 Prelude Shortthrow shifter
    ECU & Electronics
    OBD-0 PR3 chipped
    Apexi VAFC
    MSD SCI-L
    MSD Blaster SS Coi
    OEM Honda Wires
    Place Racing Wire Harness
    Removed A/C and P/S
    Audio
    Alpine 3CD in dash changer
    Alpine 6CD in trunk changer
    MB Quart 5.25 fronts
    Mb Quart 6x9 rears
    Zapco Symblink
    Zapco 360W Amp
    -Gio
    My E85 Turbo Build
    5280FEST
    mkymonkey.
    Engine mods.
    90 Civic Hatch altered AEM intake
    MSD Blaster Coil
    MSD Spark Plug Wires
    NGK Irridium Spark Plugs
    Suspension
    Tokico HP Blues all around
    Tokico 1" Drop Springs
    riding on 14x6 Enkei Mesh rims
    Interior
    Restored interior back to LX-i Stock
    Tan Arm Rest
    SE-i Cup Holders
    Ebay Type R Shift Knob (its was only 5 bucks lol)
    ICE
    ALPINE CDE-3841 (head unit)
    ALPINE MRD-M350 (Mono Class D Sub Amp)
    JL Audio 300/4 (4 Channel Full Range Amp)
    Two 10" JL Audio W3's in a custom box
    Infinity 6 1/2" Kappas (front)
    Blaupunkt 6x9's (rear)
    Soon To Come
    SE-i Rear Disk Conversion (already own)
    Brembo Slotted rotors all around
    EBC Green Stuff break pads
    SS Stainless Steel break lines
    Pacesetter Headers (for now)
    Custom Exhaust piping
    Magnaflow muffler
    Bullard123
    1988 Honda accord Lxi
    Exterior
    Fiberglass Z3 fenders
    90-93 integra full body kit
    black widow front bumer
    spiderman side skirts
    spiderman rear
    Toyota scion hood scoop (custom)
    Jdm sidemarkers
    Carbon fiber wiperblades front and rear
    custom clear/red tails
    H4 headlight housings
    custom two tone paint gunmetal / silver
    w/gold pinstripe
    shaved side mouldings
    tinted windows
    Drag 17x7 Jdm rims gunmetal w/polished lip
    205/40/17 Wanli tires
    Interior
    Racing black/gray seat covers
    painted interior black/gray
    carbon fiber floor mats
    "H" symbol on dashboard
    Engine
    A20A3 FI engine
    Weaopn R short ram intake
    NGK Oem sparkplug wires
    Toucan oil air breather
    Nippon Denso U groove spark plugs
    Koyo High flow radiator (soon to be installed)
    Exhaust
    Dual exhaust
    2 stainless steel dual tip high flow mufflers
    2.25 in piping
    Suspension
    Sprint 2.25 in lowering springs
    Tokico struts
    Camberkits
  1. Accord of the Month Nominations - June
    Last Post: 05-13-2009, 12:11 PM
  2. Accord of the Month Nominations - June 2008
    Last Post: 05-14-2008, 07:39 PM
  3. Accord of the Month Nominations - June 2007
    Last Post: 05-15-2007, 05:31 PM
  4. Nominations for Accord of the Month - June '05
    By NXRacer in forum Accord of the Month Archives
    Last Post: 05-20-2005, 09:21 AM
  5. Accord of the Month Nominations for June
    By Dibbs in forum Accord of the Month Archives
    Last Post: 05-10-2004, 12:12 PM
