Hey, I'm new on this site. And hoping to get some help. I have an '82 Accord. It was getting 34 mpg before it lost compression in #1 and 2 cyl. I pulled the head and had a valve job done. Before my compression was about 145 pounds. Now it's 180 pounds on all four. My problem is that when I start it up I have to spray starting fluid in and then hold my hand over the carb and rev it to about 2k rpm. My guess is that it's a vacuum leak. I'm not sure where. I've got all new gaskets. If I can't get this figured out, is there another, maybe, aftermarket carb that doesn't use vacuum lines so I can strip all this vacuum stuff and go back to basics. I'm an old school guy that is pre-smog. As of Jan. 1, 07 this car will be smog exempt, yeah. Also, is there an auto supply who knows their stuff that I can talk to? Thanks for any help you can give.
oldsteveo
