I discovered that my torque rod bushings are basically gone, so I've ordered new ones from Majestic. What I want to know is, can they be replaced without loosening the bolts on the center beam under the engine? The OSM specifies that the torque rod bolts be tightened before the center beam bolts. Does it matter if you're just replacing the torque rod bushings? Also, will it suffice to simply support the engine on a jack while I do this? I guess what I mean is will the engine fall towards the front of the car when I take out the torque rod bolts? It looks like the front engine mount should hold it up, but I'm sure someone here has done these bushings before and can provide some insight into potential pitfalls.....
