ok after taking my headliner out of the car several times it was shot,I got lucky,I found one at the yard out of a sedan in almost perfect condition, I have to cut it down and modify the rear trim to fit the hatch,and some of my modifications like the dome light and the overhead switches,but it's not too bad. I also found a set of sunvisors with no rips or tears,and they just need to be cleaned. it's that standard light grey color honda uses in most of the cars,but it's too nice to recover,it matches most anything I believe. I also found three good grab handles out of a sedan. on the hatch passenger side,and drivers side,all you need are some nut plates to clip in place. they bolt right in. on the back,the mounting pads are there,but they need to be drilled for the pin hole,and the metal needs to be tapped at 5X.8 mm for the screws. why in the world they didn't have grab handles in the back of the hatch,I'll never understand. right now I just have a mess,all my overhead wiring and relays are taped in place on the roof. LOL
