Results 1 to 5 of 5
Thread: Car stumbles when it wants to.
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    so yeah. when its idling, its fine...but when im going 55-60, it stumbles a bit. im throwing the egr code (im getting one from b20a86lude i guess???) and when it stumbles i can flick the ignigtion from on to acc for a sec then back, and it will clear the stumble for a few minutes. the car never dies, and it doesnt do it when im just sitting. maybe fuel pump? injectors? i dunno.
    - Justin
    shepherd79's Avatar
    Falling Waters, WV USA
    Re: Car stumbles when it wants to.
    a few choicese:
    1. check spark plugs, distributor car and rotor. Make sure they are not burned and look good. clean the plugs.
    2. clean fuel injectors. use seafoam, B12 or Red line stuff. all 3 work great.
    3. You may have water in your gas. I know that because that is what my does right now, and i know it is not injectors or plugs or cap and rotor. use some Iso-heet. Great stuff.
    Oct 2002
    87 busted ass hatch
    Salem, OR
    plugs, cap, rotor are on my to do list...but i dunno about gas. wouldnt i get some kind of stumble all through acceleration? it only does it when im at a steady speed (55-60) for more than 5 minutes really. it doesnt bog down, it just stutters like its a misfire or something. ill check the cap,rotor, and plugs later...now=sleep.
    - Justin
    10 sec 87 honda accord Lx-i
    Hamden,Ct
    Also check the vacumn advance it can cause a stumble under accec.
    1987 LXI Honda Accord
    Idaho
    I have this exact same problem right now and am trying to fix it... WITHOUT taking it to a shop. im not a mechanic tho
    when my buddy helped me replace the head, I fiddled with the EGR valve connection to the exhaust manifold... and now im getting an EGR valve ECU idiot light code. in 3rd gear i get this code going 40 mph and in 5th gear i get this code at 60 mph. 4th gear not sure... i know i get it... jsut not sure what exact speed is. I dont wanna know how to bypass the EGR... I want to know what i should check to make sure all the connects/vacuums are hooked up right.
    I have checked the dist cap/plugs and they are fine... its been doing this for a few months... but its just a beater atm. Im looking to fix er up.
    with this code...where do i start?
  1. car stumbles under 3500rpm?
    By sjsjbb in forum EFI Tech
    Last Post: 07-04-2006, 12:37 AM
  2. car stumbles above 3000 rpm
    By alexkol in forum 3geez Accords
    Last Post: 08-04-2005, 07:19 PM
  3. engine stumbles and dies
    By fur_fenton in forum 3geez Accords
    Last Post: 04-29-2005, 09:22 AM
  4. Engine stumbles at 3000 rpm
    By bkcorso in forum 3geez Accords
    Last Post: 04-21-2005, 07:25 PM
  5. Transmission stumbles
    By accordlx in forum 3geez Accords
    Last Post: 06-04-2004, 03:48 PM
