anyone who has 4 or 5 point harnesses where did you hook 'em up?
ok....
first off:
harnesses WILL kill you unless you have a roll CAGE. not just a bar. you need a roll bar / harness bar to properly mount them, but you could also mount them to the rear upper seatbelt mounts.
the only harnesses I would install on a street car are schroth rallye 3 harness. it is designed for one of the shoulder straps to break away in the event of an accident, thereby letting your head/neck move out of the way, instead of snapping your neck in the even of a rollover accident.
http://www.apexperformance.net/cartg...id=1018&cid=13
please please dont install a harness unless you mount it properly, or use a roll bar at bare minimum. if you dont know what i mean by mounting it properly, you dont need harnesses.![]()
