I am buildin up my a20a1 for all motor. I plan on runnin dual carbs, but for now i have the 32 36. high compression is also on my list. I have a full exhaust. Im rebuilding the motor right now and i want to know what kind of compression is good to have to have a lot of power, but only what the stock rods and topline pistons and rebuild kit can handle. I also plan on running a 50dry shot. I know milling of the head and or block will be req'd but how much? i have the 282 delta which is increased duration but lower lift. Im concerned about valve interference. Ideas? also does milling affect valve timing?? could it be beneficial??
