Please help wahts wrong with my accord 3g?
After starting engine releasing park brakes and pressing one time brakes pedal this bulbs on dashboard going to light again and didnt swittching off.
sorry for bad english
Let's clarify for a sec.
You start the car
You release the parking brake
You press the brake pedal once
And then lights come on on the dashboard.
Did I get that right? And do all the lights come on or is it just the brake lights?
yes that's right
both lights
Hmm...
Have you tried driving it? Do the brakes work?
brakes work - fine
liquid fresh - was changed about month ago.
brakes liqud sensor - work. was tested by tester.
Sounds like your emergency release switch is broken or doesn't want to turn off.
check that.
I know this may be something that has already been checked but, when the light for the brake lights comes on in the picture of the car that means there is a brake light out.
mine does that to as soon as i start my car and tap the brake the brake light turns on and all the lights work fine.
same here
If all your brake lights are good then you guys may want to check and see if he White/green wire running from the left brake light sensor to the safety indicator in the dash is grounded. If its not then check the grounds from the failure sensors. If their receiving ground then your failure sensors are probably bad.
were can i check to see if its grounded and are the falure sensor's the black boxes next to the lights in the backOriginally Posted by EricW
On my 87 LX, when this happens, it may be a wrong brake bulb installed, a connection to the failure sensor,(a little black plastic box under the taillites and also the rear window lite) or a bad sensor itself. I think the fact that it doesn't come on until you hit the brake eliminates the low fluid sensor, which is on the same circuit, and points to the bulb , sensor, or connectionto the sensor. Good luck.Originally Posted by Dump0k
see mine was always on and it buged the crap out of me. so one day i checked all the lights. they still worked when i pushed the brake but they would not turn on when i turned on the headlights...it came out to be a bad fuse...i checked it and replaced it...later that week it poped it again....i was mad so i ran a wire from the turn signal to the wire direct...i think my fuse box was creating a ground and poping my fuse.
does that mean i need more blinker fluide or brake flude lol but ya the brake flude sensor is on the brake lamp sensor as well thats kind of oddOriginally Posted by Accordaone
so yours doesent come on anymore and what fuse number is it that was popingOriginally Posted by MessyHonda88dx
it was the left side tail light... now it does not come on since i put a wire from the switch to the line with out a fuse...seems to work fine...i remember it was a 10amp fuse and then i put in a 15 but it poped it...so had to rewire it.Originally Posted by ghettogeddy
Ok as I understand I've to check wires to failure sensor and sensor too.
Thanks
P.S. is it possible to make lite WAP version of forum for mobile surfing?
