Ok so how do you know if you have damaged valves from a broken timing belt. I removed the valve cover and nothing looks bad unless there is something special i should look for... Anyone???? Is it something obvious or do you have to actually remove the head or anything like that? I need an answer as soon as possible. Thanks guys!
