Accordtheory
The ELD is the other thing in addition to the VSS that is not compatible as stock with obd1. I am trying to figure out if the ELD is why my idle is so retarded. It constantly revs up and down, revving up maybe at least 10 times in a row at a stoplight before dropping down to 800 or so rpm. The ELD code is the only code I have left. I already changed my IACV, same thing. I also tried to adjust the idle bypass screw on the TB, just made it worse. If the ELD is really what's causing my incredibly annoying idle, I need to figure out how to fix that..
Any ideas, anyone? I know I'm being lazy, I haven't researched this yet, but I'm hoping it will be an easy fix that someone already knows, like the VSS fix.
