I have all my wiring sorted out on the conversion harness but pins A21 and A22 on the OBD1 plug. What pin on the OBD0 plugs do i need to run these to wires to?
Also does pin D2(brake switch) need to be connected to anything?
I'll have to check my conversion harness for pin A21 and A22. However, I'm sure you can leave the brake switch out.
I need these parts!
A21 to the igniter/ignition control module
A20 is to the purge solenoid
I know what they are, I need to know where to run them on the OBD0-OBD1 conversion harness.Originally Posted by thegreatdane
???? You havent got any ICM on your pre-OBD wiring and you dont have the purge solenoid either (unless you have 88-89 injection). So therefore there's nowhere in the stock ecu plug to put those wires.
In case you have 88-89 injection the purge cut off solenoid should be on pin B2.
Ok, thanks. I'm just trying to minimize the problems/codes i will have when i finally get everything done.
