Results 1 to 14 of 14
Thread: Oil Pan & Valve Cover gasket question..
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Question Oil Pan & Valve Cover gasket question..
    Some of you guys that tried varies brand name of valve cover & oil pan gaskets.
    Which gasket works best for you, some aftermarket valve cover & oil pan gasket like Fel-pro or does OEM Honda gaskets work better?
    Edit- Just wondering what some other results where, cause I'm having a problem with aftermarket brands.
    SE-i Sedan 5 spd
    Re: Oil Pan & Valve Cover gasket question..
    The longer I have my car, the more I find myself buying Honda brand stuff. It's just not worth it anymore to try to save a couple of bucks. So much aftermarket junk nowadays goes from one factory to another, whatever is cheaper. Brand X might be good today and horrible tomorrow. Honda and Toyota are who they are because they're very good at putting together great parts with skilled assembly. Try Majestic Honda - 25% off list.
    http://www.hondaautomotiveparts.com/...catdisplay.jsp
    SEi User
    Feb 2004
    Panama City, FL
    I haven't done a oil pan gasket yet, but i have done a couple valve cover gaskets. All of the valve cover gaskets have been felpro. Recently i have just been reusing the old one since it is only maybe a year old, but I applied a thin layer of 5 min gasket maker to both sides of the gasket and haven't had any leaks.
    Pgm-fi conversion 4-16-05
    OBD1 11-25-06
    Turbo 2-26-07
    Ichiban's Avatar
    North of You.
    I rebuilt my 20R/22R with fel-pro, and federal mogul rings and bearings. Everyone else I know uses Fel-pro as well.
    I find it is the quality of the prep job, not the gasket itself that makes it work. I use a 3M pad on my die grinder to clean up pan rails and a wire wheel or bead blaster on the pan itself (gotta be careful to get all the sand and crap out after)
    ICHIBAN!
    "Now, even more better!"
    Ichiban's Avatar
    North of You.
    A lot of newer engines dont have a pan gasket per se...just the gooey crap.
    ICHIBAN!
    1988 Accord LX-i
    Delaware County
    I used a fel-pro when i replaced my valve cover gasket.
    Nov 2000
    I have used Felpro, whatever brand NAPA carries, and Genuine Honda. For the money, there is nothing easier than changing the gasket AND grommets when adjusting the valve lash. I was reasonably happy with Felpro if you want to save the trouble of mail ordering, but the Honda gasket works a little better (less leakage at the corners). The various gasket making compounds work well, I am sure, but why go to the extra mess and trouble?
    Nov 2002
    Ridin Dirty in New York
    stock honda for me
    '91 Accord Wagon (F22B1 with H23A1 Pistons) '98 Accord LX (Wife's) '88 Prelude Si (B21A1), '85 CR-X Si (D16Z6)
    Salem, Oregon
    Part number in question is the 11251-PC6-010, and Honda list is $26.75, but I can ship them out for $20. OE Honda, or OEMs OPT and Ishino, and that goes for ANY gaskets. They may also be sold under the name "Stone". Use a thin layer of Permatex Ultra Gray or Hondabond on both sides of the gasket. Not as big a deal with 3G and earlier cars, but the Blue/Black/Orange/Red Sealants are usually NOT Oxygen Sensor Safe, and will kill you sensors in a hurry. The biggest problem we see with pan gaskets is they are never torqued correctly. Always too loose or so tight that the gasket is squishing out.
    Visit us at www.valleyspecialists.com for all of your Honda and Acura Parts and Service needs!
    Nov 2000
    I was talking about the rocker cover gasket. I paid to have my oil pan gasket changed and they did use a Honda gasket as well as the gray "pookie" stuff that the Honda dealer uses.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Interesting points, appreciate the feedback. I'll prep the surfaces real good & use "hondabond" with OEM gaskets next time around.
    Hate pulling the exhaust out to change the freaking oil pan gasket again..
    carotman's Avatar
    Montreal South Shore
    Yeah it's a bitch to pull out. I did mine with no adhesive at all and it doesn't leat. I used a torque wrench to secure it in place tough.
    I need these parts!
  1. Valve Cover Gasket
    By bushbean in forum 3geez Accords
    Last Post: 07-23-2007, 12:09 PM
  2. valve cover gasket...
    By gsus in forum Classic Honda Community Chat
    Last Post: 01-24-2005, 01:03 PM
  3. valve cover gasket
    By 89accord_lxi_coupe in forum 3geez Accords
    Last Post: 09-04-2003, 09:14 AM
  4. valve cover gasket
    By 2old_honda in forum 3geez Accords
    Last Post: 03-24-2003, 08:49 PM
  5. valve cover gasket question
    By buish in forum 3geez Accords
    Last Post: 12-11-2002, 01:14 AM
