how do i find TDC on the head? i think my timing is a little bit out, the car doesnt turn off like it should, it runs for about the extra few seconds and from older topics it said the timing or the idle is out so yeah, thats why i wanna know. a ACCURATE tdc, not just a thing where the pulley is facing up and the 2 marks are inline with the head
and i think my car is using waaay too much petrol than it should, i put $20 in and that moved the needle to under a quarter tank and only been 14km and at home adjust things now the needle is just on the white mark of E. also theres liquid comming outta the exhaust, would that be petrol or condensation? if you wipe it with ur finger it doesnt evaporate like petrol
and what need replacing here, accelerator cable or the pedal? can start the car up and itll run fine or idle very high, but if i put my foot under the accelerator and pull it out then the revs will drop to a reasonable number, or just stall the car o.O
could those 2 last problems be a shitty carb? i havnt flipped it but i have had it on a about 45 degree angle when i had the head off
tia
