Results 1 to 8 of 8
Thread: engine light
    1988 Accord LX-i
    Delaware County
    engine light
    I was driving earlier and the engine light came on so i turned off the car and checked some stuff out and turned the car back on and it was off. About an hour later it did it again and i turned the car off then back on and it stayed off since. Any idea what it could be?
    Re: engine light
    hey who need those little lights anyways mine has always been on since i bought my car/check o2 censor
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    Re: engine light
    leave the car on when the light comes on, then check under your seat.
    - Justin
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: engine light
    im pretty sure its going to be the egr, since you put that new header on
    -Gio
    My E85 Turbo Build
    5280FEST
    LX User maxsideburn's Avatar
    1990 Honda CB7 Coupe, 1992 Eagle Talon TSi AWD
    Lafayette, Louisiana "The Hub City"
    Re: engine light
    heh, yeah, EGR. Mine does that shit too. It comes on about 20 minutes after I start driving. Good luck getting the EGR off of the manifold without a sledgehammer too, those little bolts get practically welded to the lovely aluminum manifold.
    I read somewhere that marijuana effects the memory. Can't remember where I read that. -- maxsideburn
    LX User paso100's Avatar
    Mar 2005
    1988 Accord LX-i sedan
    Central California Coast
    Re: engine light
    Check your ECU below your seat. Your dash light is meant to go off when you turn your ignition off. Your ECU won't change till you reset if by removing your clock/ECU fuse in your engine bay or disconnecting your battery.
    Flip down that tab and see how many times your ECU is flashing
    Check here to interpret the codes:
    https://www.3geez.com/forum/showthread.php?t=185
    If it's flashing 1x or 2x it's your O2 sensors. Try reversing them and see if that helps. It did for me when I put on my Pacesetter header.
    1988 Accord LX-i
    Delaware County
    Re: engine light
    It doesn't even do it anymore, lol.
    Re: engine light
    reversing them? So an 88 has more than one o2 sensor? I always kinda figured 88-89 had two of them.
  1. Battery Light + Check Engine Light
    By tedhodges in forum EFI Tech
    Last Post: 12-28-2006, 08:34 AM
  2. engine light
    By EX-ileAccord in forum 3geez Accords
    Last Post: 07-13-2006, 06:10 AM
  3. Engine Light
    By infecto in forum 3geez Accords
    Last Post: 06-03-2003, 07:58 PM
  4. Engine Light
    By Janiel in forum EFI Tech
    Last Post: 04-09-2003, 09:53 AM
  5. Engine Light
    By k2000accord in forum 3geez Accords
    Last Post: 01-20-2003, 09:13 AM
