I bought this cheap central locking kit I bought for cheap from local auction site. This central locking kit comes without remote, I'm going to install alarm later. The kit comes with a wiring harness, linkages, lock fittings for the linkages, screws, and a control module.
Front door:
Remove the door trim
Insert a flathead screwdriver to remove the clip for the winder
Pull the panel slowly
I know its ugly!
Pull out the plastic and remember to put it back once done.
Take a good look inside the door while locking/unlocking it to see how everything works.
Test fit:
I didn't take a pic on where the actuator attached to but you get the idea. make sure it doesn't interfere with window mechanism or other things
bracket attached:
Linkage bent to attach to the stock lock linkage:
