Results 1 to 4 of 4
Thread: holley 3236
    DX User 89accorder's Avatar
    Jun 2005
    1989 Honda Accord LX
    Columbus Ohio
    holley 3236
    Ok, i got a 3236 off of ebay, and i think everything is good, but i can see the fuel float through the top of the carb!! is that normal??
    32/36 holley 282 delta cam
    pacesetter 421 header 2-1/4 exhaust(not mandrel bent)
    2 A20A1's gettin ready to rebuild one of them(not sure which), and swap to integra tranny
    Re: holley 3236
    you mean from the top down? There is a vent to vent the float bowl gasses so that the carb can suck them up. It probably helps in the float adjustment... there needs to be some way for air to get in there to put pressure on the fuel. Running with and without an air cleaner probably effect the pressure thats available to the float.
    Jun 2005
    Columbus Ohio
    Re: holley 3236
    also, when my primary barrel is up fron on the intake manifold, the linkage is on the left side, and so is the fuel feed. is this bad? can i flip the carb around and run it the other way?
    Re: holley 3236
    you should be able to turn it around with no problem.
  1. Replies: 58
    Last Post: 03-28-2013, 12:52 PM
  2. Holley 5212
    By Buzo in forum Carburetor Tech
    Last Post: 03-08-2011, 06:00 PM
  3. Holley 32/36 DGAV
    By garfunkle55 in forum Carburetor Tech
    Last Post: 12-11-2008, 05:32 PM
  4. holley 32/36
    By 89accorder in forum Carburetor Tech
    Last Post: 02-15-2006, 09:07 PM
  5. holley carb
    By Zufer in forum Performance
    Last Post: 08-02-2003, 06:49 AM
