guyhatesmycar
The one gen shares the same rear, transmission, and side engine mounts (bolt pattern on block is same, actual mounts are different) as the 3rd gen accord. The front mount is different and the crossmember is too close to the front of the engine to allow the front exhaust on ET, ES and A series to pass between. Also the engine bay is shorter, leaving little room for your intake. You're on your own for axles, as they are slightly shorter than 2nd gen axles and solution in the 2nd gen FAQ won't work for you.
