Results 1 to 3 of 3
Thread: Tune up?
    Tune up?
    Hello all my first post! I have a question I have a 1988 accord 2.0 carb 5spd. (155000 miles) Under acceleration and crusing the engine seems to surge a little, not real bad but you can tell, any ideas? It might be related but when I listen to the muffler sounds like there might be a little miss. I am going to change the plugs and wires, anymore ideas would be great. thanks
    Re: Tune up?
    Plugs wires cap rotor are all good places to start.
    Some of the surging at cruise throttle might be the vacuum advances in the distributor. Around 55 mph the come in and out alot.
    Also search the carb section there alot there to look thru as well.
    As long as your MPG is ok your prolly ok right now.
    '91 Accord Wagon (F22B1 with H23A1 Pistons) '98 Accord LX (Wife's) '88 Prelude Si (B21A1), '85 CR-X Si (D16Z6)
    Salem, Oregon
    Re: Tune up?
    Only replace the wires if they are damaged and causing misfires. Also, only replace them with good quality units like OE Honda (Sumitomo), NGK, or Magnacore. Don't buy the crappy carbon film wires you get from most companies (including Bosch and ALL HOUSE BRANDS). NGK or Denso Plugs are really the best plugs, and the underhood sticker will tell you which model to use (should be NGK number BPR5EY-11). Unfortunately, there are two DIFFERENT distributors that you may have. One by Hitachi, and one by TEC (has the igniter bolted to the outside of the housing). Do make sure you get the proper cap and rotor.
    Visit us at www.valleyspecialists.com for all of your Honda and Acura Parts and Service needs!
  1. how to, tune up? please
    By jamesh23 in forum 3geez Accords
    Last Post: 01-07-2009, 07:07 PM
  2. DIY tune up?
    Last Post: 12-26-2008, 03:47 PM
  3. 300 000 + Kms Tune Up
    By JFreddy in forum EFI Tech
    Last Post: 12-15-2006, 05:26 AM
  4. I need a tune up!
    By Aarie$$oul in forum 3geez Accords
    Last Post: 10-01-2003, 06:18 PM
  5. tune-up
    By 89accordboi in forum Carburetor Tech
    Last Post: 12-11-2002, 06:56 PM
