I know there was someone on here a while back that was working on a prototype for quad coils or something, but im thinking about doing it, and it may be a different way....
Basically use the dizzy to send the 12V needed to the coil for it to fire.... So essentially, you put just a 12V positive to the INGITION on the dizzy, and each of the 4 points will have a wire provide power to the 12V input on the coil, and the coil directly hooked up to each plug...
And in theory it should work, the dizzy will act as a trigger to turn on/off the coil.
Theres 1 problem I see with it though, the coil might need more than 0.07 seconds to get to full power to give the plug sufficient power.... and also, im not sure if theres any good gains out of this idea either. All I need is 1 more coil to try it... ive already got 3 (2 in this car, 1 in donor).
Any comments/suggestions?
