Hi,
I'd like to remove the EGR valve to clean the carbon deposits out, along with the EGR tubing. I have an '86 Lxi Accord - fuel injected. I loosened the vaccum pipes and was able to access the two bolts with a socket wrench, but I can't get the socket on straight since the socket interfers with the top of the EGR valve.
I tried putting a closed end wrench on the bolts, but it will not fit since the side of the wrench hits the side of the valve. It seems like to get a clear shot at them you need to remove the valve cover, fuel pipes and a whole bunch of other stuff. What have you done - it seems like a real pain.
Thanks,
David
