Results 1 to 11 of 11
Thread: ES2 vs A20 Transmission
    2ndGenGuy
    Guest
    I was just wondering, if it's so much easier to bolt the A20 engine to the ES2 transmission when doing an A20 swap, why would I want to keep the A20 transmission? What are the differences between the two?
    I would like to not swap axles, wheel bearings, etc. It would be nice to keep my stock drivetrain. Is it not as stout at the A20 transmission?
    I'm not going to do a really heavy rebuild of the A20, so I don't think that the ES2 tranny will have any problems holding together power-wise. I'll do the A20 tranny / axles / bearings if it's worth it.
    Ichiban's Avatar
    North of You.
    Re: ES2 vs A20 Transmission
    I was wondering that myself, I got the prelude twin carb engine and tranny, and it's set up for the big axles. After I bought the BT-1 because I wanted fuel injection and planned on keeping the prelude tranny. All the late 2g accords up here had the 1598cc 12 Valve engine so I don't know if those trannys bolt up to anything, but they do use the smaller axles.
    ICHIBAN!
    "Now, even more better!"
    PhydeauX's Avatar
    Eastern Penna
    I don't know all the reasons for changing out the transmission. The ES2 transmissions have smaller (in size not ratio) gears. That persumably would make them weaker then the a20 trans, though I don't think any one has managed to break one. Then again I don't think anyone is running a turbo on the ES2's trans so they might not survive as well under extreme punishment. The a20 also uses a slightly larger clutch, I forget what the diameter of the disk is but its some where in the ball park of 10mm i think. The ES2 has a lighter flywheel though and the extra clamping force can be made up buy a stronger clutch.
    I don't see any reason not to use the stock trans. The ratios are probalby pretty close to the carbed a20 trans but no one knows for sure yet. For what you're planning the stock trans should be fine. If you really want a trans upgrade the 85 twin carb prelude trans uses the same axles/clutch as the ES2.
    andy
    2ndGenGuy
    Guest
    I am planning on putting a stronger clutch in anyways. The OEM replacement clutch in my car wasn't holding as well as I think it needed to at the track.
    Doesn't the A20 redline at 7000RPM? I don't have the gauge cluster anymore, so I can't remember... Wonder how runing the ES2 tranny 800RPM above redline would affect it... Guess it wouldn't be for long periods anyways, only momentarily.
    I think I'm going to to with the ES2 tranny, and just see how it goes. I might have it rebuilt because the 1st gear synchros are starting to get a bit worn. Could the ES2 tranny be built up a little tougher while its being rebuilt? What would I ask them to do?
    Can't do it myself cos I don't know shit about trannys. I'm learning enough just trying to get the damn A20 out of my 87. Putting it in the 84 should be an experience.
    PhydeauX's Avatar
    Eastern Penna
    I'm pretty sure the engines redline at about the same. Either way the redline shouldn't effect the transmission nearly as much as the engine. The #1 killer of transmissions is torque, and a midly modified a20 should be well within the limits of the trans.
    andy
    carotman's Avatar
    Montreal South Shore
    Yeah, the A20A redlines at 6250.
    Can't you just use the A20A trans with 2nd gen axles mated with 3rd gen inboard joints?
    I need these parts!
    2ndGenGuy
    Guest
    I suppose I could... but It just seems so much easier to use the ES2 transmission. Gotta bolt up one of the transmissions, and if there's no serious benefit to either of them, why not do the easier one? At least that's how I see it. Besides that, I don't think I'm ready to venture in to the world of rebuilding CV joins.
    Feb 2016
    So will a es2 transmission work on the a20 or not I'm a newbie here
    Yes if you want to swap in a smaller flywheel and clutch setup, and have smaller inboard axle stubs.
  1. Is it the transmission?
    By slowsixtyseven in forum 3geez Accords
    Last Post: 03-19-2005, 08:04 PM
  2. Transmission
    By Rell in forum 3geez Accords
    Last Post: 05-25-2003, 04:29 AM
  3. transmission
    By juiquan in forum General Engine Swaps
    Last Post: 12-05-2002, 07:05 PM
  4. new transmission
    By 2old_honda in forum 3geez Accords
    Last Post: 11-26-2002, 06:00 PM
  5. transmission
    By accord_lx_86 in forum 3geez Accords
    Last Post: 11-02-2002, 03:18 AM
