Hi ok I dont know where to start, well here it goes I was going home its about 35 degrees celcius here, the car thermoter was where its supposed to be in between hot and cold. But I was coming back and there was a clunk in the transmission. I accidentally switched to neutral at a stop light and when i was going i switched it back to drive at about 3400rpm so there was this clunk. ok so anyways it kept driving but when i switched to drive between neutral it kept going to high idle on neutral. The car is extremely hot right now and I know the transmission is a bit short on oil although it cant be that much. Basically the transmission is idling much higher now, rather than the usual weak 600-900rpm it is at 1100 rpm during a stop and on idle its at about 1900rpm. Anyone know whats wrong? Is the transmission Fu@%3d or should i just let it cool down and it will be fine, I took off the passenger side wheel and everything was extremely hot, burnt my fingers on the lugnuts and all, there didnt appear to be any leak and everything looks fine, so what do you guys think?
